Parts -
3D printer source files from dragonator.
4D Systems 4.3 inch touch display (datasheet) (programmer).
8 gig micro SD card.
Adafruit PowerBoost 500 charger/booster (datasheet).
Lipo 2500mAh 3.7v battery.
USB breakout board.
10 Position rotary switch.
3 orange LED's (Radio Shack).
1 red LED (Radio Shack).
1-10k resistor (Radio Shack).
2-220ohm resistors (Radio Shack).
The Build
It all started with the dragonator's files. I simply downloaded and printed them. I used two different colors because I wanted to test each printer head, as it was a new printer. In hindsight, I would have kept it all black. Also, the friend I'm making it for will be doing the painting and touching up the finer details and minor imperfections with some type of putty.
Mounting the Display
This was somewhat annoying because the mounting tabs for the display were only slightly off. I had to break the tabs off and make custom mounts to hold it in place. If anyone tries to replicate my work, I would not recommend mounting the display the way I did. In the Mark 2, the mounts will be much better.
The Power Circuit
The Adafruit power circuit serves four purposes:
That little board of theirs does all four of these things.
Programming the Display
The 4D Systems 4.3 "Intelligent" display is programmed with the free Workshop 4 IDE. This program gives you four different options to use - one of them being the Visi Genie. This is a WYSIWYG programming interface, and the one I chose to use. I wanted to see how far I could take this project without using any code - the idea being that someone with only a very limited amount of electronic experience could replicate my project.
That's right. I did not have to write a single line of code for this project.
Each image that is painted onto the display is called a "Form", and you can make as many Forms as you want. Each screen was made in MS Paint and loaded into the Form as a JPG image.
I used this video to grab screenshots of the many different Pipboy avatars. Then I used the "User Defined Button" option to make buttons out of areas on the screen. This allowed me to make a button out of the area around "RADS", "S.P.E.C.I.A.L.", and all the other 'button' areas of the JPG images.
The IDE allows each User Defined Button only one action. The one I chose just loads a particular Form. So if the user presses the area around RADS, the RADS Form gets painted onto the display.
It should be noted that this method is not optimal, but necessary in order to avoid code and a separate microcontroller. For instance, each Form has many different buttons, all mapped to other Forms. The result was slightly over 200 User Defined Buttons. These ate up the limited memory on the display, and prevented me from making any other Forms. :-(
If I was making this from scratch again, I would make a single Form with several buttons, and then make a "Home" button for each of the screens that led back to that Form.
Display GPIO
The 4D Systems display has 5 GPIO pins that can be accessed from the IDE. The way they work is straight forward. You load an input or output 'tack' into Form 0, and then link it to a single action. For the Low Battery screen, all I did was link an input tack to load the Form that had the Low Battery image on it. Attached to the input pin is the LB signal from the adafruit board. So then that pin goes low, it triggers the Low Battery Form.
For lighting the 3 LED's, I just linked the action of the button to an output tack (as opposed to loading a Form) and tied the output GPIO directly to the LED. So when the button is pressed the action is to pulse the GPIO pin assigned to it. A schematic of the wiring is provided in the Downloads section below.
Making the Pipboy Wearable
The original design has slots built into one of the main sections with the idea of feeding Velcro straps through them and wrapping around the forearm. This simply did not work. I decided to use compression to keep it stable, and use a locking clip to hold the Pipboy in the compressed state.
The foam you see taped to the back of the battery is actually from the packing box for the display. It was a perfect fit! On the other side of the Pipboy, I used spray glue to attach a thick piece of wool, and then attached some felt.
When you put the Pipboy on your forearm, you compress the foam and this puts pressure in the form of friction on the forearm and the Pipboy. You lock this pressure into place with the locking clip, and this friction keeps the Pipboy secured to the arm, while the felt makes it comfortable and enjoyable to wear.
Downloads
Display Source (Open with Workshop 4D).
Display mount STL files (not recommended for new design).
Wiring Diagram.
For more detail and pictures, go to my blog page.
