Rotary Tool (Dremel Like) Mount
A project log for CNC Mod Pack
Here lies some 3D printable modifications for the generic CNC machines found on AliExpress like the 3018, 2418 or the 1610
Brandon PinerBrandon Piner 02/05/2018 at 04:550 Comments
I have made a mount that will slot into the z-mount from previous logs. This mount is intended to hold a dremel-like tool - in this case it is the Tork Craft Rotary Tool.
The latest version STL files can be found here:
https://www.thingiverse.com/thing:2748598
I designed this in Autodesk Fusion 360. My first attempt was just to see if the concept would work so I did not print the whole mount. Just the bottom piece where the rotary tool slides into.
Once I did a couple trial runs with that and was happy with it, I added the top piece which stabalises the rotary tool from lateral moments.
