Soldering the PCBs
A project log for SDA - The best new PDA
Do you miss those old small devices in your palm? Don't be sad, you can always build your own!
brtnstbrtnst 11/23/2018 at 14:240 Comments
I got the second board revision made and I already soldered and tested it. I made a video of the process. It is really long and boring, because it is meant more like a video tutorial for anyone interested in building the SDA. I go through the tools needed for the job, I do some basic debugging of the board and I finish it with a working board for the new SDA.
