Mount Trinket Pro Inside Fluke 17B
A project log for Multimeter remote display
Multimeter remote display using a wireless link
ken-kaarvikKen Kaarvik 12/27/2014 at 21:493 Comments
Spent some time trying to figure out how to mount the Trinket and nRF24 board inside the Fluke securely and permanently. I've drilled two holes in the meter's PCB to mount two 2mm (diameter) brass standoffs. I cut up a plastic toy block to create an angle bracket to fasten the nRF24 board. The bracket is held in place with the same standoffs that support the trinket. The nRF24 board is then held tightly to the plastic bracket with a Rainbow Loom rubber band. The Fluke 17B draws just under 2 mA before the add circuitry and about 9 mA after.
tingu wrote 06/22/2018 at 12:33 point
The mount trinket pro inside fluke and generating the more and better board is then held tightly to the plastic bracket. Keep follow the http://www.rushmypapers.me/ site for more and great services as well, I am also getting about rubber band info.
Garcia wrote 06/16/2018 at 07:03 point
tracyrroman wrote 11/18/2017 at 10:28 point
Your exertion is hard to believe and I similar to you and skip for some more informative posts. Much thanks to you for confer infrequent in sequence to us. You have get available editorial with completely! I truthfully think this net web site needs a good agreement further attention. I’ll probable be a further time to appear at ample extra, thanks for percent that in turn and get some data( https://sovinco.com/ )to refer.
