Code
A project log for Networking Group Timing Light
A mini timing light to keep introductions brief and on task.
chad-lawsonChad Lawson 01/03/2015 at 18:580 Comments
Here is the code:
  Networking Group Timer
  Created by: Chad Lawson <chad@origamirocket.com>
  Version: 1.0
// Assign the LEDs to pins
#define RED 6
#define GREEN 5
#define BLUE 3
#define TILT 8
// Assign times to the colors
#define gTime 60
#define yTime 90
#define rTime 120
#define BOUNCE 60
// Since we are using a CA LED we need to work backwards
#define COMMON_ANODE
// Define our variables
long start;
boolean running = true;
boolean tiltState;
int bounceCheck = 0;
void setup() {
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
  pinMode(TILT, INPUT);
  // Initialize our timer
  setColor(0,0,0);
  start = millis();
  // Let's try it
  Serial.begin(9600);
  Serial.println("Let's go!");
} // setup
void loop() {
  tiltState = digitalRead(TILT);
  if(tiltState == LOW)
    Serial.print("Tilt!: ");
    if(bounceCheck > BOUNCE) {
        running = false;
    } else {
        bounceCheck++;
    Serial.println(bounceCheck);
  } else {
    if(bounceCheck > 0) {
      bounceCheck--;
  if(running == true) {
    int secs = getTime();
    switch(secs) {
      case 0:
        setColor(4,4,4);
        break;
      case gTime:
        setColor(0,255,0);
        break;
      case yTime:
        setColor(128,255,0);
        break;
      case rTime:
        setColor(255,0,0);
        break;
    } // switch
  } // if(running)
  else {
    setColor(128,0,128);
    start = millis();
    running = true;
  } // else
} // loop
int getTime() {
  long delta = millis() - start;
  int secs = delta / 1000;
  return secs;
void setColor(int red, int green, int blue)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(RED, red);
  analogWrite(GREEN, green);
  analogWrite(BLUE, blue);
  Version History
  1.0 - Initial Version (141220)
