close-circle
DIY CNC milling machine
precision light duty 3 axis vertical milling machine
close
Before this project I had built many small machines. These industrial gadgets were cool to look at, and useful too. The designs were good, but not always perfect. Eventually I learned an important lesson. The lesson learned was: 90% perfect is not good enough. So much effort is required to fabricate these parts. If the design is not perfected ahead of time, I end up with an expensive piece of "folk art". (rather than a quality piece of equipment)
The goal on this mill was to build myself a tool, as a tradesman. A serious tool built to last.
Some of the parts used in this project, I had collected in my early teens (~2005). I began designing in 2013. I began building in 2014. Three years later it is mostly finished, and in use.
HARDWARE
The hardware uses BeagleBone Black as the CPU. To make a reliable machine, I wanted to use seperate power supplies for the motors and CPU. I designed a cape called Optocape for the job. Optocape is open source. You can buy one on Tindie.
Optocape includes isolated input/output hardware, along with an LVDS serializer for a LCD touchscreen. It's a great choice for any mid-sized equipment with big motors and a touch screen.
SOFTWARE
BeagleG is a bit of open source firmware installed on BeagleBone, allowing the machine to interprite G code and control the motors. The BBB PRUs are utilized for signal generation, so there is no risk of the CPU freezing while motors are moving. It also means plenty of computing resorces available for attractive graphics and touchscreen.
BeagleG runs from the shell, so I was able to write several scripts for various technical procedures. For example, when loading a new piece of material, it is necessary to "touch-off" the endmill on the workpiece, and set this position as Z = 0. I wrote a script to make this process easier, and it is activated by an F key on the on-screen keyboard.
The front panel includes two USB type A jacks. I use my desktop PC to write G code files, then transfer them to the machine via flash drive. A script actived by F key mounts the flash drive, loads the G file, and prompts for additional parameters.
Also on the front panel is a USB type B jack, connected through an FTDI interface to the BBB Serial Debug port. Software updates and customizations are easy over USB SSH.
Adobe Portable Document Format - 196.75 kB - 02/14/2017 at 06:25
eye
Preview
download-circle
Download
  • 4 × StepperStack DGSSV2R5 stepper motor controller
  • 1 × Optocape photocoupler & video cape
  • 1 × BeagleBone Black SBC
  • 1 × Heatsink Extrusion http://www.heatsinkusa.com/
  • making of the CNC controls
    Dean Gouramanis12/13/2017 at 20:01 0 comments
    Now with the controls finished, I compiled a slideshow of images from the build process.
  • Video Explanation
    Dean Gouramanis12/09/2017 at 23:04 0 comments
    I'm trying to get a conversation started about this style of CNC controller. It can be used in 3D printers too.
  • Craftwork
    Dean Gouramanis09/23/2017 at 06:02 0 comments
  • Build complete
    Dean Gouramanis08/03/2017 at 04:45 1 comment
    It's pretty much done. I still need to install limit switches, and angular indexers in order to be able to home the machine. For now I can use it as-is. I have a feeling this machine will be a life long work-in-progress.
  • Control Unit finished
    Dean Gouramanis08/03/2017 at 04:42 0 comments
  • Custom analog panel meters
    Dean Gouramanis08/03/2017 at 04:40 0 comments
    Bezels made by machine, for machine. Here are the copper bezels for the custom panel meters. These analog panel meters show Axis and Spindle current in real time.
  • Wiring the controller
    Dean Gouramanis02/14/2017 at 07:04 0 comments
    The miniature milling machine will have a miniature electrical system. The power supplies, stepper drivers, NC controller, spindle driver, touchscreen and switches are all crammed into a 12" X 12" X 7" box.
  • New open source hardware
    Dean Gouramanis12/13/2016 at 22:42 2 comments
    The Opto buffer cape I hacked together last year worked fine, but it did'nt have enough I/O. So I designed a propper cape for BeagleBone black. It is called OptoCape.
    My CNC controller is based on #BeagleBone Black running LunuxCNC #Machinekit. The cape has 15 optically isolated outputs, 10 isolated inputs, optically isolated serial port (UART4) , and four solid state relays on-board.
    I also decided to merge a previous project of mine into the layout. So the OptoCape also contains a 12 bit color LVDS video output. This section is CMOS, and powered by the VDD SYS of BeagleBone (so not isolated...).
    The optically isolated outputs enable me to drive the stepper drivers, limit switches and other machine parts using seperate power supplies. My spindle uses a 24 VDC supply, and the steppers are using 28VDC power supply.
    I put OptoCape up for sale on Tindie, and already sold the first one. It's a good general-purpose cape.
  • Clean and relocate
    Dean Gouramanis07/03/2016 at 15:06 0 comments
    I cleaned and polished the cast iron base last week. It was very laborious, but very rewarding. This machine looks beautiful in my room. Now I have a clean dry place to work on the electronics.
  • Buffer Cape tested
    Dean Gouramanis06/15/2015 at 19:33 0 comments
    The buffer cape is wired, and tested. This cape will transfer signals between the BeagleBone, and the Stepper Drivers without sharing the same power supply. Any power surges or sparks will not reach the delicate circuitry.
View all 11 project logs
Jerry Trantow wrote 12/15/2017 at 00:37 point
Why BeagleG instead of Machinekit?
Dean Gouramanis wrote 12/15/2017 at 05:21 point
There is a bug in Linux kernel version 3.8 preventing bypass of the HDMI hardware. I was unable to output parallel video until I updated to a 4.x kernel. Then it worked fine. Last time I checked Machinekit only runs on 3.8 kernel. BeagleG does not have a fancy GUI but it works great. I like the fact that it's light weight too. Simple is good.
Jerry Trantow wrote 12/19/2017 at 15:23 point
Thanks for the reply. I was able to get MachineKit to run with 4.4 but the GUI is slow on the BBB and I've found a bunch of bugs in the remote GUIs. I will take a look at BeagleG. Seems like a simpler setup for 3D printer. I wanted the lathe and router to be standalone with MachineKit but I'm not sure I could live with the display bugs.
The 4.4 kernel MachineKit uses new device tree overlays which probably fixes your bypass problem. But it seems like most BBB users are still using 3.8.
Robert Mateja wrote 12/13/2017 at 18:27 point
FANTASTIC! Those steampunk gauge also great.
I see that driver uses DRV8818 and micro? for jog mode.Can it be bypassed for direct step/dir for drv?
Dean Gouramanis wrote 12/13/2017 at 19:54 point
Yes. This machine uses step/direction mode only (Passive mode). Active modes in StepperStack can be activated by serial command, but it boots up in Passive by default.
Boris van Galvin wrote 12/10/2017 at 02:03 point
Awesome Work!! Love your control unit!
Dean Gouramanis wrote 12/10/2017 at 22:30 point
Thank you.
georgefomitchef wrote 04/30/2016 at 20:04 point
Hello Dean!
We made some video tutorials: "how to make your own diy laser engraving / cutting machine".
Will be so great to know your opinion!Realy!
You can skype me :george.fomitchev  or  email me: gf@endurancerobots.com
Than you!
Video 1 : How to assemble MakeBlock XY plotter
Video 2: How to assemble DIY engraver
Dean Gouramanis wrote 04/30/2016 at 20:49 point
Nice music.
