Robotic 3rd Hand
The Robotic 3rd Hand is worn on the forearm and hands you a tool right when you need it.
timTim
The Robotic 3rd Hand is worn on the forearm uses a Trinket Pro as it's brain. When requested it can hand you a tool that it holds, freeing you from fumbling for it or losing it.
For a peek into the development go ahead and read all the project logs, that's where all the decisions happened.
After you gather all the items on the components list and print your parts it's time to start assembly and wire it all up! Here is the hookup diagram:
It's pretty simple. Notice that I've got an adafruit Power Boost 1000 in there instead of the 5V boost supply on the component list. The no-name boost supply I bought off ebay didn't have a fritzing component, but the Power Boost 1000 is functionally the same so it is a good stand in. If you were going to use a Power Boost 1000 then you'll need to adjust the size of the hole that made for the supply.
As you are assembling the 3D printed parts you will notice that all the screw holes are either slightly under sized or over sized. The 2-56 screws will self thread into the under sized holes and spin freely in the over sized holes. This allows the screw to securely hold the screwdriver tray while the arm that actuates the screwdriver tray can move freely. If your parts aren't going together like that then you either need to adjust your printer or adjust the sizes of the screw holes. If you are printing on UP! Mini you should have no problem, that's what I printed everything on.
Here's the code to make your Robotic Third Hand move:
// ThirdHand test script
// by Tim Giles <www.wildcircuits.com>
//servo is on Pin8
//button is on Pin3 and has the pullup enabled
#include <Servo.h>
Servo ServoA;
int Angle = 10;
int AngleClosed = 10;
int AngleOpen = 120;
void setup()
  ServoA.attach(8);
  pinMode(3,INPUT_PULLUP);
void loop()
  //update the servo position
  ServoA.write(Angle);
  delay(1);
  //check if the button is pushed
  if (digitalRead(3) == 0)
    //debounce
    while (digitalRead(3) == 0){
      delay(1);
    //set the servo to it's open position
    Angle = AngleOpen;
    //hold the servo in this position to give the user time
    //to grab the screwdriver
    delay(2000);
    //set the servo to it's closed position
    Angle = AngleClosed;
NOTE: While programming I would recommend disconnecting your battery. Otherwise the 5V boost supply will be back feeding into your computer and may do bad things. I did all my programming of the Trinket Pro with the battery disconnected.
ALSO NOTE: If your USB cable that you are programming is too long / too wimpy, you may get some weird behavior when finished programming and the servo attempts to move. This is from too much voltage drop in your USB cable which is causing the Trinket Pro to reset when servo tries to move.
  • 1 × 9g cheap hobby servo Tower Pro SG90
  • 1 × Small Screwdriver http://www.harborfreight.com/32-piece-screwdriver-set-with-tweezers-97517.html
  • 1 × Trinket Pro 5V
  • 1 × 5V boost supply takes a single cell lithium battery (3.7V) and boosts it to 5V. http://www.ebay.com/itm/360822305402
  • 1 × 300mAH single cell LiPO http://www.banggood.com/Wholesale-WLtoys-V202-V939-RC-Beetle-Quadcopter-Spare-Parts-300mAh-Li-Po-Battery-V939-07-p-49464.html I had a few lying around from my V939 quadcopter
View all 9 components
  • Final EDC Contest Update!
    Tim01/02/2015 at 15:14 0 comments
    I'm wrapping everything up for the EDC contest today. I just changed the project name to 'Robotic Third Hand' instead of 'EMG Third Hand'. I"m not sure if that is going to break any links or mess up my entry, hopefully the omniscient hackaday staff has got that all under control. The EMG just didn't make sense to keep in the name since I found the EMG part not fit for the spirit of this project.
    Here are a couple of videos of it all in action! This first video gives a good look at the whole Robotic Third Hand and it's motion.
    This second video shows a real world use case for it's functionality as I secure the lower server into a MeArm. Notice that the movement and use of my right hand is not encumbered at all by the use of the Robotic Third Hand.
    All the design file are up on thingiverse now: http://www.thingiverse.com/thing:618811.
    A few more pictures:
    I guess that's all! Happy Hacking!
    EDIT:
    I wouldn't want to get disqualified based on the technicality of pocketability of my project. I interpreted the everyday carry-ness of my project as something that you would be able to wear on your arm everyday, the contest post spelling out the rules sounds like it needs to be carried in a pocket so....
    It all fits! I still had more pocket too, I didn't push it down all the way so that you could tell that I actually had the Robotic Third Hand in there.
  • Refinement and Finishing Touches
    Tim12/30/2014 at 16:56 0 comments
    I went through 2 more revisions of the mechanical bits this week, taking me up to revision 5. I increased the movement of the screw driver by 1.5 inches, so it is much easier to grab. I also added 2 "wings" that follow the curvature of my forearm so that it fits ergonomically. One of the wings has a recess that holds the battery, the other wing has a recess that holds the 5V boost supply.
    I used a common snap action SMT button that I removed from a garbage VCR for my official button and made a printed holder that is held on my hand with a rubber band.
    I am very happy with how this all works. I'd like to add the flashlight functionality and an area to hold several of the screwdriver bits, but I'm not sure that I will have time to do that before the end of the contest. In the event that I don't get that done, I will continue development beyond the end of the EDC contest as I tweak this to my liking. :)
    In the next few days I need to post up all my design files and put together some build instructions to make sure that I meet all the requirements of the contest.
  • Mechanical Motion!
    Tim12/23/2014 at 03:00 0 comments
    Since the last update I was focused on getting the mechanical motion really nailed down. I went through 3 revision of the mechanical bits.
    I didn't take any pictures of revision 1. That was more or less just a test to see if the geometries I was working on would even print.
    Revision 2 is pictured below. It is 3 sections screwed together. My printer is an UP! Mini (which I think is a fantastic printer) but it only has a roughly 4" print bed, and this contraption was a little more than 5" long. Having it be 3 separate sections also made the design a little easier. I'm doing all the 3D modeling in Design Spark Mechanical and I'm learning a lot along the way. Before this project I only ever used design spark to make really simple parts, but this project is forcing me to learn how to use it well. This revision didn't work out awesome. I wanted the screw driver to get slanted up when fully extended, but I didn't get my hinge points correct with this model to make that happen. I also had a few interferences with the arms when trying to move over the full range.
    Revision 3 of the hardware is a big improvement over revision 2. Trying to fix some of the interferences of revision 2 lead me to realize that the right most section of the design really wasn't necessary. I could instead make the whole third section an arm. And it needed to be contoured to the screwdriver holder to make it fold up nicely. With the 3rd section gone I could now print sections 1 and 2 as one piece, so I merged them together and moved the Trinket Pro a lot closer to the servo.
    Revision 4 is going to be necessary to fix a few more issues. The screwdriver needs to extended about an inch further to your hand to make it easy to grab. Also I need to integrate a small battery area. I don't think I'm going to use my 18650s, I got a cheap 5V boost supply that can run off of a single lithium cell. I'm going to see if some of my small indoor quad batteries will drive it OK.
    I threw together a real quick servo moving sketch for the Trinket Pro and put on a button so I could see it in motion and test fit it on my arm.
    Lastly - I've decided to scrap the EMG circuit. Even with everything all tuned up well, it is unreliable. I probably just need to buy a nice set of skin probes, but my home made probes are difficult to get good skin conductivity. And I don't want to muck around with probes that wear out and require a conductive gel to be used. That would just be a barrier to this thing actually being useful. I haven't decided yet how I will actuate it, but the EMG is out the door. Now I need to think up something creative that the EMG in my project name should stand for. Suggestions? I'm thinking Electro-Mechanical... Glove? Gauntlet?
  • EMG is working + Test Carrier
    Tim12/16/2014 at 01:45 0 comments
    Since my last update I populated my EMG sensor board and made a few changes to the design. I had put down a MAX1720 switched capacitor voltage inverter to create the negative voltage, but found that it's switching noise was corrupting the output of the first amplifier. The MAX1720 has an ~11kHz switching frequency, making it very difficult to filter out. If I was using something based on an inductor with a ~1MHz switching frequency it would be very easy to filter out. I used series 35 Ohm resistors followed by 47uF caps for both the V+ and V- supplies to filter them. This seems to have been enough to fix that issue. However, while testing the next day I forgot that the absolute maximum Vin of the MAX1720 was 6V. I tried the EMG board with 6V while troubleshooting what was actually a probe/skin interface issue, as I remembered that all the OPAMPs should be perfectly fine at 6V. Sadly, that blew up the MAX1720. So for the time being I've wired around the MAX1720 using 2 18650 battery cells to test. Once I have everything working I'll replace the MAX1720. I bought 2 of everything when I ordered my EMG parts last week. :0) I figured that something like this might happen. With the batteries I have confirmed that the EMG circuit is up and running.
    I 3D printed up a test carrier housing for the EMG board, trinket board and batteries. I find time and time again that it is best to have boards in some sort of case / development fixture when I'm working on things like this. With the wires all over the place traces get ripped off of boards, or random screws on my workbench will short out the connections on the board. I integrated a belt loop feature on the side of the test carrier so that I could strap the whole things to my arm for testing. I just determined that the loops need to be improved because the elastic material that I got to use as straps doesn't stay put in them like I thought it would.
    With the batteries in I didn't have any way to measure the current draw so I busted out my mega-sweet Seek Thermal Camera to see if it was getting hot. It was not, so all was good.
    The next big step is working on the mechanicals of this contraption. Hopefully what I have floating around my head is actually creatable. :)
  • The Beginning
    Tim12/09/2014 at 03:16 0 comments
    I have been dreaming up this project for a long time, and the Trinket Everyday Carry Contest is the perfect excuse to actually do it. I started about a week and a half ago to acquire parts and brainstorm how I'm going to create this thing.
    Before I read about EMGs, I was planning on wrapping a flex sensor around my forearm and hoped that I would get enough feedback out of it that I could detect patterns of muscle movement. Some preliminary experiments make me think that would be either very difficult or unreliable.
    I found the "Muscle Sensor V3" (http://www.advancertechnologies.com/p/muscle-sensor-v3.html) and thought that would be perfect for what I want to be able to detect... but $50? I probably would have paid $20, but $50 was out of the budget for this project. The guys at Advancer Technologies were nice enough to post all their schematics though, so I took that design and improved it with a MAX1720 switch capacitor voltage inverter so that the EMG circuit can run on a single cell. (The opamps need a +, GND, and - voltage rail). All my parts arrived for the EMG circuit from Digikey today (12/8/14), my Trinket Pro arrived sometime last week. Friday at lunch I took advantage of my at work access to a T-Tech pcb mill over lunch and cut out the board that I drew up for the EMG circuit.
View all 5 project logs
Erik Lundqvist wrote 06/01/2016 at 10:58 point
Impressive!
baslisks wrote 04/20/2015 at 00:25 point
why don't you use a passive return mechanism? you would use a bit less power with probably a bit more reliability.
Dylan Bleier wrote 04/17/2015 at 12:01 point
now make it screw in screws quickly with a motor, instead of having to use your hand, without over-tightening the screws
Tim wrote 03/27/2015 at 11:59 point
This morning in saw an article about my Robotic 3rd Hand project on 3Dprint.com!  Pretty sweet.  http://3dprint.com/54010/robotic-third-hand-tool-holder/
Michele Perla wrote 01/09/2015 at 09:07 point
Dude you really deserved the podium for the Trinket EDC Contest! Kudos!
Jasmine Brackett wrote 01/07/2015 at 22:53 point
Congratulations Tim on getting third place in the Trinket Everyday Carry Contest!
A Hakko FX888D with a tip kit AND a Panavise 324 Electronic Work center should be on it's way to you soon.
Tim wrote 01/07/2015 at 23:08 point
Thanks! I'm very happy and excited to use my new equipment!
Mohan wrote 01/06/2015 at 01:43 point
What a cool thing :) Hats off Tim.
Mike Szczys wrote 01/05/2015 at 22:20 point
Wow, great design work on this one. If this little contest is really what finally convinced you to start work on this project we need to do a log more of these!
Tim wrote 01/06/2015 at 22:27 point
Thanks Mike! It turned out to be a fun and useful project. I think that HaD should definitely do more of these. Any idea when the contest results will be announced? The anticipation is killing me!
Sparkmike77 wrote 01/02/2015 at 23:01 point
I'm trying to print out the STLs, but the scaling is tiny. What's the base unit you used? Inches, cm, mm?
Tim wrote 01/02/2015 at 23:34 point
I designed it in inches. Try scaling by 25.4
davedarko wrote 12/23/2014 at 14:20 point
using a tower PRO servo controlled by a trinket PRO to hand a pittsburgh PRO screwdriver - very much PROfessional, sir!
Tim wrote 12/23/2014 at 14:26 point
I hadn't even noticed the PRO level I was achieving.
