Frickin Laser Beams!
A project log for Can I borrow a feeling?
or, how I can access a random emotion at the press of a button.
Sascha GrantSascha Grant 12/20/2014 at 13:370 Comments
The last few evenings has been spent trying to figure out just how much space the screen, trinket and battery take up and designing an appropriate enclosure in CorelDRAW.
Well, that's done & I've now run the job in the laser :)
The thin pieces in the middle are to space the screen enough as to have it fit below the front clear pane.
And here's the front assembled - there's a few dust spots that I'll remove before final assembly :)
The CorelDRAW file for the box is available on GitHub - https://github.com/ibuildrockets/Borrow_A_Feeling/tree/master/box_files
Next steps - glue the box together and solder up the buttons & screen. Getting close to finished now!
