Board design with RGB camera
A project log for Square Inch To Space
Send your own hardware to space
paul-kocylaPaul Kocyla 03/30/2015 at 17:360 Comments
The board design is finished. The board is shorter so it can be deployer from a 1U PocketQube.
A new high temperature supercap will be mounted on the bottom side.
Here are two options how the deployment mechanism could work.
