IMAGER on the chipstar
A project log for Square Inch To Space
Send your own hardware to space
paul-kocylaPaul Kocyla 02/27/2015 at 11:181 Comment
I decided to include an image sensor on the chipstar.
This will make it more exciting, because you will be able to see the earth, the moon and the sun.
An integrated algorithm will also provide data how fast and in which direction the seen object is moving.
The sensor is black&white with 20 pixel resolution in X/Y - not a high end camera, but you can print the earth´s image into the frequency spectrum and use it for navigation purposes.
I think that will be a motivation :)
trialexhill wrote 06/11/2020 at 05:08 point
Hi - I know this was a long time ago, but what was the part number of the image sensor you tried? Thanks!
