Deployer Electronics
A project log for Square Inch To Space
Send your own hardware to space
paul-kocylaPaul Kocyla 03/07/2015 at 19:280 Comments
Designing the electronics for the Chipstar Deployer.
It will have a radio for receiving earth commands and a hardware timer to trigger the deployment even when the controller fails to work.
This system will be redundant with two different power sources.
The two trigger systems will be: Nicrome wire cutter and motorized lock
In the lower section of the PCB you can see the constant current driver for the wire cutter.
