openHAB binding improved
A project log for AGCON - Arduino Generic CANopen Node
Hardware and software to build many different devices that can communicate via the CANopen protocol.
jens-geislerJens Geisler 03/07/2015 at 21:190 Comments
A test setup with an RPi running openHAB and fitted with a home-made CAN bus shield, connected to an Arduino programmed CANFestival CANopen device with some sensors is on the way.
