Transfer to Protoboard
A project log for Trinket Pro Multi-Readout Multimeter
This portable device gives a live read-out of current and voltage between your DC power source and your load! (max 26V DC, 3.2 A).
john117John117 12/23/2014 at 04:540 Comments
After getting the Trinket, LCD, and INA219 to work on a bread board I drew up everything on Fritzing so I had a reference should anything go wrong whilst transferring onto a permanent proto-board.
I intentionally soldered on female pins so that:
1. All components could be easily replaced should they fail.
2. Components could be upgraded such as the LCD from size 16x2 to 20x4.
3. I could remove and use the components for other concurrent projects to save money.
