Hackaday.io Hackaday.io
Sign up Log in
ProTrinket Ultra-Ranger
Measure distance and view it on demand using a ProTrinket, an Ultrasonic ranging module and an LCD screen.
fotis-papadopoulosFotis Papadopoulos
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
34 followers
  • Description
  • Details
  • Files 0
  • Components 10
    • View all
  • Logs 11
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
686
0
34
7
Team (2)
  • fotis-papadopoulosFotis Papadopoulos
  • konstantina-kastanaraKonstantina Kastanara
Join this project's team
ongoing project
ultrasonic protrinket Pocket-sized
This project is submitted for
  • The Trinket Everyday Carry Contest
This project was created on 12/13/2014 and last updated 11 年前.
Description
The purpose of this project is to create a pocket-sized tool for measuring distance from objects. We are going to need an ultrasonic ranging module to get the distance between our tool and the target-object. Pushing a button connected to the ProTrinket will trigger the sensor and then the distance from the object will be displayed on the LCD screen. We would also like to create a 3D-printed case for our tool and make it look cool!!!
Components
  • 1 × ProTrinket Adafruit's ProTrinket with atmega328 microprocessor
  • 1 × Ultrasonic ranging module Started with Sharp's 2D120X IR sensor, but switched to an ultrasonic sensor with bigger range (HC-SR04)
  • 1 × PushButton 4x-pin pushbutton
  • 1 × LCD display with I2C I2C compatible lcd display
  • 1 × 10K resistor
View all 10 components
Project Logs
Collapse
  • Ultrasonic Trinket with LCD and button
    Konstantina Kastanara • 06/06/2015 at 06:42 • 0 comments
    Replaced potenciometer with 2 resistors and added button to turn on LCD backlight!
    Konstantina Kastanara • 05/16/2015 at 09:32 • 0 comments
  • Ultrasonic Trinket video
    Konstantina Kastanara • 03/14/2015 at 12:28 • 0 comments
  • ULTRASONIC TRINKET with LCD display and on off button code
    Konstantina Kastanara • 03/14/2015 at 11:58 • 0 comments
    Find Ultrasonic Trinket with LCD display and on off button code here!
  • Ultrasonic Trinket with LCD display and on off button photos
    Konstantina Kastanara • 03/14/2015 at 09:54 • 0 comments
    Konstantina Kastanara • 03/14/2015 at 09:48 • 0 comments
    Rebuilt the project using one breadboard. We also added a button which turns on the sensor and the LCD only when pressed.
  • First version of our code
    Fotis Papadopoulos • 02/07/2015 at 13:09 • 0 comments
    Find more details here!
  • First version of our project
    Fotis Papadopoulos • 02/07/2015 at 13:04 • 0 comments
    We built a first version of our project using a Pro-Trinket 5V plugged into FTDI and USB.
  • New Sensor
    Fotis Papadopoulos • 12/20/2014 at 14:43 • 0 comments
    We found a better sensor, which is not InfraRed, but it's ultrasonic with a bigger range.
  • Now gathering the stuff we need
    Fotis Papadopoulos • 12/13/2014 at 13:19 • 0 comments
    We're now gathering the things we're going to need.
View all 11 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The project uses a combination of ultrasonic sensor, a buzzer and LCD display.
Project Owner Contributor
Object detection using HC-RS04
fikunyinadebolafikunyin.adebola
A button in a bus that notifies the driver if you feel unsafe or possibly in danger.
Emergency Bus Button
trevor-andersonTrevor Anderson
This project will count the number of pieces of candy that are dropped into your child's candy basket!
Halloween Candy Counter
justin-lutzJustin Lutz
First embedded system project
Development of an automatic irrigation prototype
adrian-hinostrozaAdrian Hinostroza
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ProTrinket Ultra-Ranger", please tell us the reason.
Send message
Remove Member
