• New IR Library
    Theo01/09/2015 at 22:05 0 comments
    I found this great library for transmitting and receiving IR signals. It didnt really make sense to write it all from scratch so I have switched to using this. I have rewritten the interface to display the different protocols.
  • TFT Display
    Theo12/30/2014 at 17:47 2 comments
    My display finally arrived. I got it up and running pretty painlessly thanks to this ILI9163C library, and Adafruits GFX library. This makes it much more standalone as it removes the need for a serial terminal. I have also put the code on github (link on the side). Next I plan to add some buttons to switch modes etc.
  • NEC Protocol Decoding
    Theo12/14/2014 at 21:50 0 comments
    I am using the TSOP38238 38kHz IR reciever which has a photo detector and preamplifier in one package. This means I can connect it directly to the arduino. I don't have my LCD yet so I am working on decoding some common IR protcols and printing to the serial output. I have made a basic decoder for the NEC protocol which seems to be working well, although it is a little buggy. Interestingly the device id for my no-brand TV is actually 0x00, thats not a bug. I found a helpful resource for IR protocols here. I will put my source code on github shortly.
