Someone was faster ^^
A project log for WiFi_LightSwitch
An ESP8266 powered low-cost/low-energy WiFi controlled relay circut for DIY home-automation :D
janJan 11/26/2015 at 17:480 Comments
so someone has done the most of the work using the Arduino ide, so here you go http://iot-playground.com/2-uncategorised/40-esp8266-wifi-relay-switch-arduino-ide
when i finished my other Project i will make an iOS app (and web based app) for it
