Hackaday.io Hackaday.io
Sign up Log in
ESP8266 EasyIoT Arduino library
With ESP8266 EasyIoT library making WiFi sensors is easy. Create WiFi Arduino sensor with couple lines of code.
easyiotEasyIoT
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
30.2k views
1 comments
245 followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
30.2k
1
245
53
Team (5)
  • easyiotEasyIoT
  • ernesto-pareja-jErnesto Pareja J
  • devtdevt
  • brahimoussama1993brahim.oussama1993
  • phanisillaphanisilla
Join this project's team
  • ESP8266 EasyIoT library
  • iot-playground.com
ongoing project
arduino wifi sensor ESP8266
Related lists
ESP8266 Projects
Projects utilizing everyone's favorite $5 WiFi Module
Atmel Arduino Projects
Arduino is an open source hardware platform for making interactive objects that can sense and control the physical world.
This project was created on 12/19/2014 and last updated 3 年前.
Description
ESP8266 WiFi modules are cheap (3 USD) and can be used for WiFi sensors. But working with ESP8266 AT commands is not easy. Our goal is to create ESP8266 library which can help to build sensor with couple lines of code. We go beyond simple test example with ESP8266 module.
Components
  • 1 × ESP8266 module
  • 1 × Arduino Pro mini 8Mhz 3.3V
  • 1 × AMS1117 3.3V regualtor
  • 1 × 1000uF capacitor
  • 1 × DHT22 temperature and humidity sensor
View all 8 components
Project Logs
Collapse
  • ESP8266 WiFi plant irrigation system
    EasyIoT • 06/11/2015 at 10:53 • 0 comments
    Added ESP8266 WiFi plant irrigation system example.
  • ESP8266 LED dimmer
    EasyIoT • 02/11/2015 at 09:48 • 0 comments
    Added ESP8266 LED dimmer tutorial.
  • ESP8266 real time clock
    EasyIoT • 02/04/2015 at 07:51 • 0 comments
    Added ESP8266 real time clock example.
  • ESP8266 air pressure and weather forecast sensor
    EasyIoT • 01/31/2015 at 21:11 • 0 comments
    Added new ESP8266 air pressure and weather forecast sensor.
  • ESP8266 WiFi water leak (soil moisture, rain) sensor example
    EasyIoT • 01/26/2015 at 07:48 • 0 comments
    Added new water leak (soil moisture, rain) sensor example.
  • ESP8266 WiFi relay switch example
    EasyIoT • 12/23/2014 at 09:26 • 0 comments
    We created ESP8266 relay switch example. Sources for ESP8266 WiFi relay switch example can be found on GitHub. Tutorial how to build ESP8266 WiFi relay switch is also available.
  • ESP8266 WiFi temperature and humidity sensor
    EasyIoT • 12/19/2014 at 10:42 • 0 comments
    We create first WiFi sensor with DHT22, ESP8266 and Arduino. It looks messy but works ok.
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
fabix683 wrote 12/22/2014 at 12:53 • point
news for thies job?
Build your IoT in couple of minutes
Project Owner Contributor
EasyIoT Cloud
easyiotEasyIoT
ESP8266 based soil moisture sensor Wi-Fi enabled.
ESP Soil Moisture Sensor
yancanyancan
monitor temp and humidity with graphs and CSV download
DHT22 Node WebUI
marcel-ochsendorfMarcel Ochsendorf
A smartish home system with Arduino IoT devices and a Clojure cloud back-end with a web interface.
Homefront
harri-ohra-ahoHarri Ohra-aho
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266 EasyIoT Arduino library", please tell us the reason.
Send message
Remove Member
