ESP8266 WiFi relay switch example
A project log for ESP8266 EasyIoT Arduino library
With ESP8266 EasyIoT library making WiFi sensors is easy. Create WiFi Arduino sensor with couple lines of code.
easyiotEasyIoT 12/23/2014 at 09:260 Comments
We created ESP8266 relay switch example. Sources for ESP8266 WiFi relay switch example can be found on GitHub. Tutorial how to build ESP8266 WiFi relay switch is also available.
