Graphing battery voltage
A project log for The Pi Watch
A watch with a Teensy 3.1 at it's heart. It's a Open Source development system that you can wear!
ipaq3115ipaq3115 01/12/2015 at 21:010 Comments
Did a full run down of the battery with the watch recording voltage. This is super easy to do because the BC127 does all of the battery management. Most of this just involved writing the library routines to poll the bluetooth and I just now got the recording to a file and graphing part working good. Next up is battery stats and building a lookup table to turn the voltage curve into a more linear 0 - 100% capacity kind of number.
EDIT: Put in some min/max voltage numbers and you can see the whole charge cycle.
