All of the juicy stuff is in the "build instructions" section.
Details of how I succeeded in reading from an SDHC card using the BP and an LC STUDIO module/breakout.
There are a few things to know about the LC STUDIO module:
With these things in mind, we can (using a breadboard) connect the Bus Pirate to the module in the following way:
Note that we're using the 3.3v supply to power the module, and we're also connecting this to the Vpu pin on the BP. We do this because we're going to use the open drain form of the BP's SPI mode.
In addition, I've connected inputs 0 through 3 of my Logic Pirate to MISO, CLK, MOSI and CS. This will give me a nice low-level view of what's going on.
Once that's all in place, we finally insert our SDHC card into the module's socket.With BP hardware version 3.b and firmware version 6.1, the default SPI mode parameters are all that's required to speak with the SD card. Following a BP reset or power up, the following is sufficient to set up the BP:
HiZ>m 1. HiZ 2. 1-WIRE 3. UART 4. I2C 5. SPI 6. 2WIRE 7. 3WIRE 8. LCD x. exit(without change) (1)>5 Set speed: 1. 30KHz 2. 125KHz 3. 250KHz 4. 1MHz (1)> Clock polarity: 1. Idle low *default 2. Idle high (1)> Output clock edge: 1. Idle to active 2. Active to idle *default (2)> Input sample phase: 1. Middle *default 2. End (1)> CS: 1. CS 2. /CS *default (2)> Select output type: 1. Open drain (H=Hi-Z, L=GND) 2. Normal (H=3.3V, L=GND) (1)> Ready SPI>
Note that I've just hit Enter all prompts save the first.
Now we turn on the on-board BP power supplies and activate the pull-up resistors:
SPI>W POWER SUPPLIES ON SPI>P Pull-up resistors ON SPI>We're now ready to start talking SPI to the SD card.
SD cards are conversant in two different protocols: a native high-speed protocol and a low-speed SPI protocol. The SPI protocol is supported to make it easy for microcontrollers to store and retrieve data from the cards. However, once powered up the cards default to the higher speed protocol. We therefore have to explicitly tell the card that we wish to speak SPI.
The procedure for doing this is quite straight forward, although there are a number of steps. It is described in full in the Physical Layer Simplified Specification. One of the main reasons for writing this mini-guide is to record the initialization steps I finally used.
Firstly, some background. Each SD card command has an index running from 0 through 63. Each command is issued by sending 6 bytes via SPI to the card, with the CS line held LOW. The first of these is 0x40 ORed with the command index. The next four are arguments to the command or zero if no argument is required. The last byte is a CRC value computed from the 5 command bytes. (The algorithm for computing this value is described in the spec, but it is not straightforward to compute by hand. A tiny C++ program for computing these values can be found at https://github.com/hazelnusse/crc7.)
The first command we issue is CMD0, which resets the SD card:
SPI>] r:8 [ 0x40 0 0 0 0 0x95 r:8 ]
/CS DISABLED
READ: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
/CS ENABLED
WRITE: 0x40
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x95
READ: 0xFF 0x01 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
/CS DISABLED
SPI>
The "] r:8" at the beginning gives the card some clock cycles to finish doing anything it may have been doing before we issue the command. "[" causes the CS line to be brought low, after which we send the 6 command bytes (the 6th 0x95 being the CRC value for the command). We then read in 8 bytes before sending the CS line high again.The second byte read is the command response. The format for this response (an "R1" response) is described in the spec. The value 0x01 means that the reset command succeeded and the card is in the IDLE state.
Getting this far is actually a minor victory in itself, as it means that we've successfully used the LC STUDIO module to connect to the card. Using the Logic Pirate to look at the above exchange, we see the following:
Channel 0 is MISO, channel 1 is the clock, 2 is MOSI and 3 is CS. The trace circled in yellow is the SD card responding to our reset command. (It's ALIVE!)
The second command we send is CMD8. This is required for newer SD cards and lets us inform the card of the voltage we are operating at, giving the card a chance to tell us whether this is ok. We pass an argument of 0x00 0x00 0x01 0xAA. The 0x01 specifies a desired operating voltage range of 2.7v to 3.6v. The 0xAA is a "check pattern" that will be echoed back by the card on success. The following shows how this command is sent using the BP:
SPI>[ 0x48 0 0 0x01 0xaa 0x87 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x48
WRITE: 0x00
WRITE: 0x00
WRITE: 0x01
WRITE: 0xAA
WRITE: 0x87
READ: 0xFF 0x01 0x00 0x00 0x01 0xAA 0xFF 0xFF
/CS DISABLED
SPI>
The response format is "R7" which includes an "R1" as its first byte: hence the first "0x01" in the response. Following a few zeros, we see another 0x01 indicating that the voltage range is accepted, as well as the check pattern 0xAA echoed back, indicating success.The next command we send is CMD59 to turn off the CRC checking. This makes issuing subsequent commands much easier, as we no longer have to compute these values. The CRC for CMD59 however must still be correct:
] r:8 [ 0x7b 0 0 0 0 0x91 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x7B
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x91
/CS DISABLED
SPI>
Again we see an R1 response indicating that the card remains in the idle state.Next is CMD58 which is used to check the contents of the OCR (operating conditions register):SPI>] r:8 [ 0x7a 0 0 0 0 0 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x7A
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
READ: 0xFF 0x01 0x00 0xFF 0x80 0x00 0xFF 0xFF
/CS DISABLED
SPI>
I don't actually know if this is required for initialization, but it's in the spec. You could try leaving it out.Lastly, we need to issue the application-specific command ACMD41. Application-specific commands are issued by first issuing CMD55 followed by a command with index 41 (it would be CMD41 if not for the CMD55 prefix). The 30th bit in the ACMD41 argument is used to specify whether the host (that's us!) supports high-capacity cards. We need to set this bit, otherwise the command will return an error as this is an SDHC card. The command is issued as follows:
SPI>] r:8 [ 0x77 0 0 0 0 0 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x77
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
/CS DISABLED
SPI>] r:8 [ 0x69 0x40 0 0 0 0 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x69
WRITE: 0x40
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
/CS DISABLED
SPI>
Note that the R1 response of ACMD41 is still 0x01, indicating a card in the idle state. This response indicates that the card is still initializing. We repeat ACMD41 until we see a response of 0x00:SPI>] r:8 [ 0x77 0 0 0 0 0 r:8 ] r:8 [ 0x69 0 0 0 0 0 r:8 ]
/CS DISABLED
/CS ENABLED
WRITE: 0x77
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
/CS DISABLED
/CS ENABLED
WRITE: 0x69
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
WRITE: 0x00
READ: 0xFF 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
/CS DISABLED
SPI>
Got it in one! Note that we don't have to worry about the argument to subsequent ACMD41s - only the first one matters. (This cuts both ways - if you stuff up the argument on the first call to ACMD41 you'll need to start over.)We now have an SD card successfully initialized in SPI mode.
If you had a Teensy drivings a USB [mechanical] keyboard, what other features would you add? A Bus Pirate [or a version of it]? An SD card reader, as discussed here?
A Griffin style rotary knob?
After that, all you need is a decent LCD and the keyboard becomes a full-blown terminal.
[sigh - if only my build skills matched my ideas]
