This project waited on the shelf for so long, that I decided to scrap it and rebuild into #Hexapod Henk MkII. Go there for the latest news on the project. This project is kept for archive.
The legs are arranged in a circle, every 60°. The alternative was to have them in two rows, but they seemed to be too close together that way.
The power switch has a couple of 47kΩ resistors added to it, which form a voltage divider, connected to an analog pin. This way I can tell the battery voltage, and monitor it. Since the analog pin also doubles as DAC pin, I had to remove the speaker. It's a bit of a shame, but it was too quiet anyways. I might add a proper audio board in the future, if really needed (or monitor the voltage differently).
deʃhipu
, you can see that there are several UARTs available (the red squares). Each has RX and TX pin. If you look at the servo controller's pins
Hans Jørgen Grimstad
Thanks alot ! This is very helpfull, I ll give it a try.
