All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
Thanks, probably will update the highlight library. It also looks like multiline section was classed as python instead of cpp.
I tried to change it to C++, but it just doesn't want to stay in C++.
Still won't change to C++ for me. The code doesn't understand lines are enclosed in multi-line comments. End results are not much different.
Oh yeah sorry, I meant the new version 'will' work better. I'll see about getting in the next deployment.
I am adding another log and my first code snippet has the same type of multiline comment, but it shows up correctly. It is not the multiline comment that caused the highlight issue.
if you need more code snippets to debug, this seems broken too https://hackaday.io/project/158460-sound-button-hack/log/146415-arduino-code
Dear support,
I would like to ask You a question. What about adding an option to unsubscribe from some contest?
There is an option to add project into som list like "Hackaday 2018 price contest" But I didn't see any way to remove the project from list. Eg someone needs to fix a bug. So if it's not too late, it's fine to remove it before ending.
Thank you
If you need this asap, change the project to private, save, and then back to public. Private setting will remove the project from current contests.
Good to know, thank you. What about some likes/comments, will be removed in private mode? And also, will be available after bringing back to public?
Likes, comments, and follows are not removed. But while private it will only display likes, the others return when switched back to public.
Hi - inviting people to join a project from the project page seems buggy. I find the person in search and try to add them but usually get the message "Something is wrong. Please try again." Is there another way to adding people to a project?
Update: adding people from the "edit project" page seems to work better!
The map on the Hackerspaces page is completely unusable on mobile - it doesn't seem to support touch events. The only things that work are the buttons (zoom, etc.) but I can't even pan the map. I'd suggest using Leaflet for the map.
Also, LOGS view ought to list links to all logs as an Index so it's easy to jump to one particular log quickly without having to scroll through the logs.
Hey Anool, you can condense all of the logs and it becomes an index. There's an expand/ collapse button on the top right of the logs.
Can the "ADD COMPONENTS" part of the Project be made more user friendly. Adding each component, one line at a time is really awkward. Shouldn't it be possible to parse and read a CSV file to build a BoM, just like Digikey or Mouser?
@Sophi Kravitz , @Lutetium , @Aleksandar Bradic
To be honest, I would really overhaul the whole components, files and assembly instruction sections — move them to a separate subpage, for a start, displaying them together.
Hey Anool,
We have tried to provide some of this capability via a FC Pro Open Hardware integration, but it hasn't been publicly visible nor directly integrated into the core Hackaday.io flow. We'll make sure to prioritize this. Thanks!
On my netbook (ASUS 1005HA, 1024x600 screen), the top banner in the PM/Chat page is unnecessarily thick and overlaps the chat frames at the top. I can't see whether or not the top person in the list is online or not! Codefix, plzkthx.
Don’t get salty, i’m sure either they’re working, considering, or it’s just you. I never liked the mobile site, it’s a pain to use.
It's actually not the mobile site that's being served to my netbook. I'd be even louder if it was...
HI @Starhawk we hear you and appreciate your feedback! Lots of improvements in the works. Thanks for the comment.
Can you make the world icon in the public chat bigger please.
Some of us Dinosaurs already see double ;-)
On tagging and inviting people- When you tag someone with a generic name in the chat, like steve of something, there's 100 of them, and the chances of the one you want popping up in the 5 that you can choose from is very slim. Also, i tried to invite @Austin Tomson to the #Chat for Drones, and he didn't show up. Idk what's the problem with it.
Not sure why Austin won't show up, but another option to look into is enabling a public chat for the drones project. A public room skips the whole invite process, and you get a public chat button on the project page. You can still invite contributors to the existing chat room. https://cdn.hackaday.io/images/7148251524677483235.png
Sure, try it out and let me know what you think. Just to be clear, you will see two rooms in chat, the public one will have a world icon. You can share that URL and visitors can see the chat but not post until they register and join it.
it's a neat idea i guess, but i would rather it just make the original room public, instead of two seperate rooms. It's kinda confusing, i don't know which to post in
the spam is becoming a downer more and more, could you share some thoughts on how you'll work on it? What's in the pipeline? Strategies?
btw. I've already reported the person a while ago - 184 projects by now https://hackaday.io/hacker/298411-lee
Sorry, it's a priority and thanks for the reports. There are ongoing changes to existing strategies as they find workarounds. It needs to be done in a way that doesn't impact everyone else's experience.
I don't think anyone feels the need to post +20 projects a day, so maybe a restriction is something everyone can live with. I think shadow banning and some more moderators could help for a start. (I came back to say it's 208 projects now)
some of that is already implemented, and you should see less spam now.
https://hackaday.io/XOCLUBXOSHOP made 509 identical projects to spam/SEO :-(
we do have a timeout for project creation, but bots just wait long enough to bypass that. we have some different strategies on, and there should be less spam now.
The ---more--- tag doesn't seem to work on the "my pages" list — the whole content is displayed instead.
Lots of seemingly pointless Chinese posts in the global feed recently.
Perhaps i should consider learning Chinese
I cannot copy code snippets from messages. rather annoying :p
Hi guys, could someone please tell me how can I review projects that I like? I could not find any list showing projects I clicked like button before. Thanks for your assistance.
Hello Mehmet! On your profile page you have "View all" button in "Projects I Like & Follow" section. Here is the link: https://hackaday.io/projects/hacker/305972/likesandfollows
Thanks a lot Lutetium! Though I would advise website developers to put a link on a more visible place such as the main menu. Cheers.
I really don't like project pages, they are cluttered and there is no clear distinction between different parts (overview, logs, discussion etc.). Makes skimming difficult.
A couple of my projects do not have the "views" counter. I saw that sometimes you have to wait a couple days for this to start but it's been >2 weeks. Is there a setting to turn this on? Thanks!
I think there is a threshold of a weird number like 80 or something
Can not delete images when editing a project. Tried that Firefox / Chromium in Linux and also in Chrome for Windows. the (X) icon points to javascript:void(o)
Sorry about that, while this gets fixed if you drag any image to first position you can click the X over the larger image above to remove it.
Thanks!! It worked. It might be the second time that I thank you since my previous reply simply vanished from the thread.
Today I suddenly noticed that I have accidentally reported my own project as inappropriate (it says "You have reported this project and we are looking into it") and I don't even know when I did that (probably on my cellphone when I accidentally touched it?). Is there anyway to withdrawal the report?
it doesn't really matter, somebody will check it over, and unless it really is inappropriate, they won't do anything. it would have to be close to a hackaday pornhub though, i mean, this is a thing- #Internet of Condoms
To clarify, there are site-wide rules and if the project violates any of these (say, explicit materials), it might get deleted - but the rules are lax enough that this is unlikely.
Same exact thing happened to me, and I also have no idea when exactly it happened... But my project "censh" has said that since the day I posted it. (I so posted on a cellphone - the button for reporting a project should probably have an "Are you sure?" dialog before doing the report)
HI there- We review all reports carefully and if the project looks like it shouldn't have been reported, we probably are just going to keep a watch on it.
I've tried to submit my project
https://hackaday.io/project/134831-atmega4809-developing-board-project
to Hackaday Prize (Open hardware) but never done. My project or my account is banned-out?
is it working yet ?
it would be sad if you couldn't participate !
I think it's extremely unlikely somebody would ban you from participation, sounds like a bug =)
Hello @kodera2t ! Are there any errors or issues during the submit process?
Yes, "waiting circle" rotating by applying to hackaday prize and never done..
Do you have any idea or is there any requirement (for example completed BOM) for hackaday prize submission. Actually none of my project cannot be. If except for me no issue, I guess I am banned out by some reason.
Have you already tried submitting to the 2018 Hackaday Prize?
That does does not work... "waiting rotating circle" forever...
Code snippet for C++ not handling multi-line comments correctly. See 3rd code block vs 1st or 2nd. in my log. The highlight is done incorrectly.
https://hackaday.io/project/158058-transistor-tester/log/146130-markus-firmware-customization
