All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
I'm not seeing an issue right now uploading, which of your projects or logs shows the black or small symbol in place of the image?
Thanks for your fast respone, it is working fine today. May be I am a little bit impatient sometimes.
HI there
My project 'view' count seems to be stuck at 890, is this normal and will it update ?
I know people have been visiting the past week so I would have thought the view count would have updated.
Project :-
https://hackaday.io/project/199227-pi-zero-2w-mini-dlna-server
Thanks in advance
Diddy
Hello Hackaday team! My project views counter doesn't move while people continue subscribing to it and leave comments.
Yes, problem has been fixed. Thank you very much for your support.
I started a new project on Hackaday. I have several keywords to facilitate searching for it, but it doesn't show up in any search results. It's been quite a few days since I started it: https://hackaday.io/project/203296-a-slimmer-10x-100mhz-differential-probe. Any thoughts on what the problem could be? My other (older) project shows up properly when I search for "Differential Probe".
Slimmer is now showing in search. There was an intermittent search data ingestion issue that was cleaned up and newish projects should be searchable again.
You can't change the email address on a hackaday account you login to with Github without a password. You can't reset the password without access to email address hackaday has. If you remove the email address with Github it doesn't update hackaday. How do you change the email address?
Use this link to set a password, https://hackaday.io/forgotpass
Then you should be able to update the email using the new password set.
I've been trying to recreate it locally but no luck, might have more info tomorrow after digging through logs.
Hmm it comes and goes. Now it works on my mobile browser but who knows what it'll be like on the desktop browser later.
Works for me now. Hope the bug has been squashed for everybody. 🤞
Same as Hsingai, my project page opens with Chrome on Windows, but on a Raspberry Pi and also on my Android phone its says:
TypeError: bla bla
URL.canParse is not a function
im getting an error tjat `URL.canParse is not a function` on several pages on my laprop swnding this from my phone check yout wnail for details
adding pictures to project logs doesn't work. I tried many images and there seems to be an image with CDN storing images. My images are small (100K) and png. so they should work.
They are working but I have seen some delay from when an image is selected and saved to when it is available on cdn. I'll reach out to operations and see what they can do.
Could the system please be fixed so project titles can include apostrophe and be shown correctly and not like ' ? It looks stupid.
I was looking at one of my projects today and noticed two usernames that I don't recognize were added to my 'Team' list for my project page. So there were 3 members of my team, myself and these two others. I took a screen shot, and then deleted them. Was my Hackaday account hacked? Who do I report this to in order that someone at Hackaday is aware.
The log page https://hackaday.io/project/7431-the-kicad-central/log/24103-kicad-links contains a link to kicad-pcb dot org which is not an official domain, owned by a non-KiCad entity, and could conceiveably host malware. It should be changed to the official site: https://www.kicad.org
OK, found the "Report as inappropriate" link. Grey on black.
HaD should enable support for uploading and storing AVIF image files. It's an open standard and all the leading browsers support it. It compresses even better than JPG. I tried it on the JPG image on my page: https://hackaday.io/page/9255-embedders-handbook and got 23% reduction (196712 -> 152183). I got a similar reduction (843007 ->667240) on a real world photo.
https://aomediacodec.github.io/av1-avif/latest-approved.html
Content server better these days but will sometimes fail to serve an image leaving a blank space. Often comes good when the page is refreshed.
Also in one instance the image was lost and I had to upload again.
The content server (for the images) is still unreliable. Often it will fail to display some images on a log or details page. Refreshing the pages sometimes works, other times not. The image is still on the server as going directly to the URL works, again sometimes. Maybe some limit or throttling of image serving is reached.
I see I'm not the first one to report this, but somehow all Hackaday notifications end up in my Gmail Spam box, with a warning that the included link is unsafe. Despite me continuously confirming that it is 'No Spam', it still keeps happening.
The image galleries are starting to fail again.. why is this happening every 2 weeks. It's super annoying.
Please check the following projects - some images are missing again:
https://hackaday.io/project/177784-lambdaspeak-futuresoft-edition
https://hackaday.io/project/172154-loudspeaker-your-microkorg
It may be time to move on to another platform.... I am loosing trust. One day, all my pictures will be gone?
It's annoying, but it's a visual issue only and not a source file issue.
1. Just a question when trying to join a project, clicking "Yes" results in no feedback
2. Diving into the problem there seems to be a rights issue with the page.
If you need anymore information please let me knowm
Can this be due to the fact that the one trying to join a team does not have the creator status ?
Currently you need creator status, but there is an upcoming patch that will remove that requirement to join an existing project.
Picture upload is broken again. ☹️ First attempt returned access denied. Second attempt succeeded in uploading but the editor showed a broken image icon. Looking at the HTML, a filename had been assigned to the uploaded picture.
Hello, at the moment I have no chance to upload a picture. Of course I checked size and file format. No chance, neither project gallery nor project log. No picture. Am I the only one with this problem? If a upload a picture in the gallery I see a black backgound, if I upload a picture (and I tried a lot of different pictures) I see a small symbol and no picture.
