CHIME RED
A Collaborative Project - Building the Hardware for a MIDI Telsa Coil Controller capable of 16 simultaneous Voices
With a share passion for Tesla Coils, a software engineer friend of mine has written some awesome Tesla Coil gate controller software that allows for up to 16 simultaneous notes (voices) from MIDI input. I was tasked with creating the bomb proof hardware that the software would run on, with MIDI I/O, various GUI controls, Fibre Output to the Tesla Coils, as well as expansion outputs for future functionality.
A performance with three Tesla Coils was done with the completed CHIME REDs to demonstrate their capabilities, and a video of my arrangement contribution (including my MechBass as an accompaniment) can be seen here: https://www.youtube.com/watch?v=Z9aqr5zQlYY
Hardware began with a custom Arduino Due shield with the various connectors and supporting components. Using this a test rig was created out of a piece of folded acrylic with the required buttons, Fibre output, MIDI I/O, speaker, and various BNC TTL Inputs and Outputs. Following this, features were CADed in SolidWorks to mill out a Hammond brand Die Cast box for the final product. Powder coated boxes were used, such that the labels for various functions could be etched with a laser engraver. Four boxes were built, with around 100 wires, soldered on one end and JST crimped on the shield end! I highly underestimated the amount of time this project would require, but it was well worth the result.
See the project log for the various stages of the design with photos, be sure to click "View all 5 project logs"!
  • The Finished Product
    James McVay12/28/2014 at 23:03 0 comments
    Or nearly finished I should say, as I'm still on the hunt for some nice shiny red potentiometer knobs
  • Component Installation
    James McVay12/28/2014 at 22:46 0 comments
    Having soldered in excess of 400 wires to buttons and various connectors, an acrylic shim is created to mount the Arduino Due, Speaker, LCD display and LCDs to. The pushbuttons and keyswitch mounting are used to bolt the shim to the hammond enclosure, while preventing the pots from rotating. A similar approach is used for the BNC connectors and Fibre transmitter to lock their rotation.
    During testing of the prototype, there was a bit too much noise present on the output of the potentiometers. As a precaution, some extra caps were ninja'd onto the potentiometer outputs (there are already caps on the shield too).
    What the enclosure looked like with the shim and I/O installed
    LCD and remaining components installed, with all the wires routed, crimped, and connected to the board.
    The small, 3D printed red plastic component above the LCD houses the status LEDs (Keyswitch, Interlock and Gate)
  • "Bombproof" Enclosure
    James McVay12/28/2014 at 22:27 0 comments
    The final "bombproof" enclosures for CHIME RED are Hammond Die Cast Aluminium Enclosures. Aluminium boxes were used to provide RF shielding of the internal components, while a black powder coated model was used to allow for laser engraving of labels.
    One the required interface and I/O layout features had been modelled in SolidWorks, the hammond enclosures were CNC milled
    Next, text labels were laser engraved on the enclosure. Careful alignment of the enclosures in the engraver was done using dry runs of the engraver tracing out the milled features using the visible red dot.
  • The Prototype
    James McVay12/28/2014 at 22:17 0 comments
    Before building the final CHIME REDs, a fully functional acrylic prototype was created to test the system design with live Tesla Coils.
  • The Completed Arduino Due Shield
    James McVay12/28/2014 at 22:09 0 comments
    The Populated Arduino Due Shield, mounted on a Due.
    • AND gate to prevent outputs from being triggered when the interlock isn't engaged as well as driving the TTL outputs
    • Interlocked based on Keyswitch Input and RC + Schmitt Trigger Oneshot (Due outputs flail on Startup)
    • Amplifier for Speaker Output to Simulate Gate Output at Bottom LHS
    • Potentiometers control Speaker Volume and Interlock Startup Delay Period
    • 6N138's for MIDI Input and Optoisolated TTL Input
    • 2 Pin Connectors for Gate Fibre, Status LEDs and TTL Outputs on the LHS
    • 3 Pin Connectors for Push Button Inputs as Labelled on RHS
    • Status LCD connector on RHS with Contrast Pot above
Eero af Heurlin wrote 08/21/2015 at 12:15 point
Schematics and Arduino code available somewhere ? I watched Josh's talk at CCCamp2015 and want to build one for my DRSSTC...
