HB100 Radar Shield
pre-amp board for the HB100/GH100 microwave sensor
This is a pre-amp board for the HB100/GH100 microwave sensor. The sensor unit is a 'homodyne' receiver, it mixes the received signal with transmitted signal to yield the difference beat tone between the two. The sensor unit has an IF output, the output frequency of the IF is proportional to speed of the object being measured:The formula listed is f = fo* [( C + Vr)/(C + Vs)] where C is wave velocity in medium, if free space @ 10.5 GHz would be close to 2.998E10 cm/sec, Vr is the velocity of receiver relative to medium, Vs is the transmitter velocity relative to medium. So its beat frequency output will be 2 times 10.5 GHz times the absolute velocity relative to a fixed object / speed of light. The amplitude will be a function of the strength of the reflected signal. Metal objects will be stronger then a hand.
Populated and tested the PCB. It works..
04-lcd-fft.tar.gz
FFT mit Wasserfall auf dem LPC1768.
x-gzip - 46.61 kB - 11/10/2022 at 11:33
Download
  • 1 × LM358N Amplifier and Linear ICs / Operational Amplifiers
View all 2 project logs
fe7565 wrote 10/26/2019 at 21:26 point
The maximum speed tested was about 200 km/h (4kHz.  How many kHz would the current setup with the LM358N function?  Does the LM358 have the bandwidth to read speeds up to  1,200 km/h for small objects (5mm metal) in close proximity (10-50cm)?
lglasgow wrote 09/19/2016 at 15:03 point
What is the cost of the boards and also shipping to Cape Town, South Africa
PakHacK wrote 08/12/2014 at 08:49 point
This is pretty cool!! How could I get a couple of these boards in Europe?
Thank you.
