Game Show Emulator
Back to overview
Play game shows with your Raspberry Pi and some big pushbuttons.
annehasseld wrote 12/07/2015 at 13:34 point
I't's me, the teacher from Michigan again.  We have built our game and have run into the problem you discuss here: When you press each button, a line should be printed out displaying which button was pressed. If lines are constantly being printed out, you may have the pi connected to a normally closed terminal instead of a normally open terminal.  Do you know how we can correct this?  Thanks so much!
