Wireless
A project log for KAPCOM
Yet another hardware controller for Kerbal Space Program. Leveraging Telemachus, Python and Arduino to drive joysticks, buttons and displays
lawnmowerlattelawnmowerlatte 05/15/2015 at 14:130 Comments
My Raspberry Pi came yesterday, so went ahead and set that up. I had a few hiccups setting up KAPCOM, but it worked once I figured those out. I ended up needing some additional software packages:
sudo apt-get install python-pip
sudo apt-get install python-dev
sudo apt-get install python-xlib
With those installed, http://setup.py happily ran and installed the other Python modules. I also set up Synergy for sharing my trackball to my KSP machine. The instructions on Adafruit were mostly correct, but I also had to run the following commands:
sudo apt-get install libcurl4-openssl-dev
sudo unzip ext/gmock-1.6.0.zip -d ext/gmock-1.6.0/
sudo unzip ext/gtest-1.6.0.zip -d ext/gtest-1.6.0/
After this, Synergy built correctly. I configured it so the mouse leaves the Raspberry Pi and never comes back unless you press F1:
section: screens
	KAPCOM-Pi:
	Mac:
		meta = alt
end
section: links
	KAPCOM-Pi:
		right(0,100) = Mac
		left(0,100) = Mac
		up(0,100) = Mac
		down(0,100) = Mac
	Mac:
		# left(0,100) = KAPCOM-Pi
end
section: aliases
	Mac:
		Mac.local
	KAPCOM-Pi:
		KAPCOM-Pi.local
end
section: options
	keystroke(F1) = switchToScreen(KAPCOM-Pi)
end
I also added a startup script to start Synergy and run KAPCOM. I tested it all out and the trackball worked great. KAPCOM is currently in a broken state because I'm still working on the configuration changes for adding multiple modes and Arduinos.
Very happy with the progress I'm making. I'm going to spend some time at lunch working on the mode and Arduino code. Once I get that done, I can go back to working on the enclosure.
