Bench Top 5-Axis Mill
A 5 axis mill for the common man.
This is currently just a glimmer in my mind's eye. The goals for this project are--hopefully--simple enough to achieve with commonly available technology. This design effort will focus on three things:
1) cost of materials; keeping the price down will be my primary goal, after all there are things like, oh, real life to pay for before my hobbies get funded. ;)
2) size; the whole mill (enclosure and all) ought to take up not more space than a commercial desktop printer (dimensions from an older model Dell were something like 30" wide x 28" deep x 30" tall).
3) relative precision; I have a preference for sub mil (0.0001") precision. While possible--maybe--I doubt I will be able to achieve that goal. I'll settle for +-.001" precision if I have to.
Given the design considerations above (in the description) a few ancilliary design restrictions can be required:
  1. Utilize as many off the shelf components as possible. This will have a number of consequences, including minimizing the design of original components.
  2. Utilize open source designs for as many of the components that required design. As above, this will minimize design time for components that required design and fabrication.
  3. Consider the tools available to the average hobbyist and design for those fabrication capabilities.
Specific Design Requirements (these are necessary for completion)
  1. Must completely fit within a W24" x L30" x H30"
  2. Must have 5 axes; 3 linear (x, y, and z), and 2 rotational (a and b)
  3. Must be able to effectively mill hardened steel, Inconel, Monel, etc.
  4. Must use as many off-the-shelf parts as possible.
  5. Must utilize as many open-source efforts as possible.
  6. Other requirements pending Collaboratorium 2.
Specific Design Goals (these are icing on the cake)
  1. May interface with PLCs.
  2. May allow for auto tool changing.
  3. May run via network/wireless.
  4. May have touchpad/other interface on the machine.
  5. May have auto material placement and removal.
  6. May detect mill-bit sharpness.
  7. May have tool magazine.
  8. May have general parts library (based on OpenSCAD or similar parametric design tool).
  9. Others? Input is welcome.
  • Lit. Review Lite 2: Frame Design Continued
    Albert Latham08/16/2015 at 19:21 0 comments
    My light literature review continues. In this rather short episode I consider more advanced math that I am rather unprepared to tackle. Huzzah for brain-pain!
    Park, Sung-Ryung, and Seung-Han Yang. 2010. “Design of a 5-Axis Machine Tool Considering Geometric Errors.” International Journal of Modern Physics B 24 (15n16): 2484–89. doi:10.1142/S0217979210065131.
    Overview
    This paper presents a kinematics drive approach for modeling and predicting volumetric error within a 5-axis mill's movement. Three mill configurations are considered, analyzed, and the critical design factors contributing to volumetric error are identified.
    How is this study useful to this project?
    This study may represent a way to identify components and assemblies that are critical to precision very early in the design phase. Further, because the math is available it may prove useful during computer driven design revisions for the identification and selection of components that minimize volumetric errors.
    What problems will utilizing this research present?
    Aside from my distinct lack of training in mathematics the largest challenge will be to appropriately integrate this into some form of computer driven task. A deeper understanding of the method and its outcomes will aid in figuring out where this will fit in the design process and what decisions it will contribute to making.
  • Lit. Review Lite: Frame Design
    Albert Latham08/16/2015 at 01:28 0 comments
    This is a lighter literature review than some applications call for. I am excusing myself from anything more deptailed until I understand the math behind most Mechanical Engineering. Currently I lack a background in Physics, Statics, Dynamics, Calculus (differential and partial differential equations), Linear Algebra, and applications there-of.
    I am taking steps to rectify these gaps in my knowledge. I have enrolled in a Calculus course at my local community college. I am enrolled in an online course for Linear Algebra and its applications (specifically in programming). I am completing a course in programming (CS50 through edX.org) after which I will be approaching Physics.
    And there is probably more that I haven't mentioned. Keeping all this straight is a task unto itself and it can be rather time-consuming.
    Complaining aside; here is what you've skipped everything above for:
    Hung, Jui Pin, Yuan Lung Lai, Tzuo Liang Luo, and Hsin Chuan Su. 2013. “Analysis of the Machining Stability of a Milling Machine Considering the Effect of Machine Frame Structure and Spindle Bearings: Experimental and Finite Element Approaches.” International Journal of Advanced Manufacturing Technology 68 (9-12): 2393–2405. doi:10.1007/s00170-013-4848-6.
    Overview
    Analysis of the Machining Stability of a Milling Machine Considering the Effect of Machine Frame Structure and Spindle Bearings: Experimental and Finite Element Approaches (hereafter "the study" or "the paper") specifically considers the combined dynamics of a vertical milling machine frame and spindle. An application of finite element analysis was used to predict the dynamics of the milling machine and spindle and an experiment was used to confirm the analysis.
    How is the study useful to this project?
    In the introduction the author's clearly state how this application of experimental and mathematical analysis could be directly useful to an end-user, saying that, "The prediction [...] of the abnormal vibration is of great importance for the selection of the free chatter machining conditions." This study aims to specifically address the dynamic conditions that result from using a high-speed spindle in combination with the mill's frame. A complete solid model is used for the analysis, rather than a simplified model (as other studies have done).
    Items that are specifically useful are the mathematics and derived equations, the mathematic modeling methodology used for the spindle unit and mill unit.
    The math presented will allow me to not have to experiment to find the modal frequency by experimentation and will thus allow a program to handle the heavy lifting (iterative design via algorithm) once the design phase has begun.
    1. Huo, Dehong, Kai Cheng, and Frank Wardle. 2010a. “Design of a Five-Axis Ultra-Precision Micro-Milling Machine-UltraMill. Part 1: Holistic Design Approach, Design Considerations and Specifications.” International Journal of Advanced Manufacturing Technology 47 (9-12): 867–77. doi:10.1007/s00170-009-2128-2.
    2. ———. 2010b. “Design of a Five-Axis Ultra-Precision Micro-Milling Machine-UltraMill. Part 2: Integrated Dynamic Modelling, Design Optimisation and Analysis.” International Journal of Advanced Manufacturing Technology 47 (9-12): 879–90. doi:10.1007/s00170-009-2129-1.
    Overview
    These studies walk through the design and implementation process of an ultra-precise ("nano-meter finish") 5-axis CNC milling machine. The first article focuses on the existing ultra-precision machines, component options, and the specifications for the proposed "UltraMill".
    The second article focuses on the modeling and simulation of the "UltraMill" with an emphasis on machine dynamics. The simulation allows the authors to predict the performance of the machine over its entire performance envelope.
    The second portion of the paper is far more useful than the first. While the first sheds some light on the goals of the entire project,...
  • Papers, Please.
    Albert Latham07/08/2015 at 21:21 0 comments
    I'm in the middle of a literature review in an effort to do two things. One, I'm looking to see what has been done before, and two, I'm attempting to sort out the math involved with designing machine tools well. Below I've the bibliographic entries for the papers I've pulled for review. I'll need to double or triple the number of papers before I will begin to understand the true nature of my undertaking.
    I'm currently working my way through the frame design portion of the list as it is the most pertinent to me right now. The results of my review will be used to select appropriate FEA and FEM software to begin design and analysis based on the design requirements.
    Frame Design
    • Bamberg, Eberhard, and Alexander H Slocum. 2000. “Principles of Rapid Machine Design.” Mechanical Engineering, 212.
    • Darvekar, Sanjay, a. B Koteswara Rao, S. Shankar Ganesh, and K. Ramji. 2013. “Optimal Design and Development of a 2-DOF PKM-Based Machine Tool.” International Journal of Advanced Manufacturing Technology 67 (5-8): 1609–21. doi:10.1007/s00170-012-4594-1.
    • Garro, O., and P. Martin. 1993. “Towards New Architectures of Machine Tools.” International Journal of Production Research. doi:10.1080/00207549308956865.
    • GARRO, O., P. MARTIN, and H. MARTI. 1992. “Algebraic Description for Machine Tool Design.” International Journal of Production Research. doi:10.1080/00207549208948179.
    • Hung, Jui Pin, Yuan Lung Lai, Tzuo Liang Luo, and Hsin Chuan Su. 2013. “Analysis of the Machining Stability of a Milling Machine Considering the Effect of Machine Frame Structure and Spindle Bearings: Experimental and Finite Element Approaches.” International Journal of Advanced Manufacturing Technology 68 (9-12): 2393–2405. doi:10.1007/s00170-013-4848-6.
    • Huo, Dehong, and Kai Cheng. 2008. “A Dynamics-Driven Approach to Precision Machines Design for Micro-Manufacturing and Its Implementation Perspectives.” doi:http://dx.doi.org/10.1016/B978-008045263-0/50007-6.
    • Huo, Dehong, Kai Cheng, and Frank Wardle. 2010a. “Design of a Five-Axis Ultra-Precision Micro-Milling Machine-UltraMill. Part 1: Holistic Design Approach, Design Considerations and Specifications.” International Journal of Advanced Manufacturing Technology 47 (9-12): 867–77. doi:10.1007/s00170-009-2128-2.
    • ———. 2010b. “Design of a Five-Axis Ultra-Precision Micro-Milling Machine-UltraMill. Part 2: Integrated Dynamic Modelling, Design Optimisation and Analysis.” International Journal of Advanced Manufacturing Technology 47 (9-12): 879–90. doi:10.1007/s00170-009-2129-1.
    • Kono, D, T Lorenzer, and S Weikert. 2010. “Comparison of Rigid Body Mechanics and Finite Element Method for Machine Tool Evaluation,” 1–26. doi:10.3929/ethz-a-006111492.
    • Li, Baotong, Jun Hong, and Zhifeng Liu. 2014. “Stiffness Design of Machine Tool Structures by a Biologically Inspired Topology Optimization Method.” International Journal of Machine Tools and Manufacture 84. Elsevier: 33–44. doi:10.1016/j.ijmachtools.2014.03.005.
    • Park, Sung-Ryung, and Seung-Han Yang. 2010. “Design of a 5-Axis Machine Tool Considering Geometric Errors.” International Journal of Modern Physics B 24 (15n16): 2484–89. doi:10.1142/S0217979210065131.
    • Zhang, Jianfu, Pingfa Feng, Chuang Chen, Dingwen Yu, and Zhijun Wu. 2013. “A Method for Thermal Performance Modeling and Simulation of Machine Tools.” The International Journal of Advanced Manufacturing Technology 68 (5-8): 1517–27. doi:10.1007/s00170-013-4939-4.
    Spindle Design
    • Liang, Yingchun, Wanqun Chen, Yazhou Sun, Nan Yu, Peng Zhang, and Haitao Liu. 2014. “An Expert System for Hydro/aero-Static Spindle Design Used in Ultra Precision Machine Tool.” Robotics and Computer-Integrated Manufacturing 30 (2). Elsevier: 107–13. doi:10.1016/j.rcim.2013.09.006.
    • Liu, Junfeng, and Xiaoan Chen. 2014. “Dynamic Design for Motorized Spindles Based on an Integrated Model.” International Journal of Advanced Manufacturing Technology, 1–14. doi:10.1007/s00170-014-5640-y.
    • Sabirov, Fan, D. Suslov, and Sergey Savinov. 2012. “Diagnostics of Spindle Unit, Model Design and Analysis.”...
  • Organization and Planning
    Albert Latham06/13/2015 at 21:27 0 comments
    I'm taking the time to properly organize and focus this project. This includes setting up project management through Asana, filling out the project files on Github, and calling for help. I'm trying to get this project done by the end of August (before I start into school again) and I don't think I'll make it by myself. There is plenty to do on this right at this moment and I'd love to start assigning tasks to people. Your level of knowledge in machine design doesn't matter as long as you're willing to teach yourself what you need to know.
    If you think you might like to help, leave me a comment below.
    What I've done:
    • Organized project on Asana.
    • Filled in the Github repository with the project framework (folders, files, proposal and project overview, etc.)
    • Called for help right here.
View all 4 project logs
