Print head v10.1
A project log for Arcus-3D-M1 - Full Color Filament Printer
Active mixing, fused filament fabrication 3D printer.
daren-schwenkeDaren Schwenke 04/05/2016 at 22:450 Comments
New stainless got here. Switched from 304 to 316. So far i'm liking it.
Slightly thicker wall stainless, so I had a little room for adjustment of my holes. Changed the angle slightly so I could Increase the clearance between the hot/cold end by 0.5mm. Much easier to work with.
Polished the *inside* of this one...
The print head struggled to maintain temps > 230C with the fan on full while it was close to the bed.
Made a new air conduit-deflector-shield-thingy.
