Artemis Status and Gigabit Transceiver
A project log for Nysa: FPGA Development Environment
Hardware and software to simplify FPGA development and interaction.
daveDave 05/28/2015 at 19:340 Comments
Artemis is alive an well!
Artemis is working really well, most days I leave it attached to a Linux server at my office and remotely play with it when I get a chance. Work keeps me really busy so I can't dedicate too much time during the day but at night it's a different story.
Artemis uses a Spartan 6 LX45T instead of Dionysus's Spartan 6 LX9, the '45' and '9' in the name is a loose indication of the programming space available inside the FPGAs so Artemis gives me roughly 5X logic space. On top of that the DDR3 hardware and HDL has checked out and man is that DDR3 fast!
DDR3
Because the Xilinx coregen creates a DDR3 core that has multiple ports a system can be designed to use many individual memory interfaces instead of using an arbiter to arbitrate the memory resource (this is how Dionysus works). This got me thinking about employing the DDR3 memory in more applications. It sounds great but writing custom DDR3 controllers for each high throughput cores is a big deal. After thinking about it for a while I decided I should write a DMA controller that has a simple FIFO like interface this is trivial to implement in a custom core. This way instead of attaching cores directly to memory I can attach them to a DMA controller and let it route the data to/from the DDR3 as needed. The DDR3 is so fast it can absorb data at a higher rate than most of the peripherals can generate or absorb. So it makes sense to use it as a buffer.
I finished a version of the DMA Controller. It ended up having 4 input ports and 4 output ports, it can be configured using 8 instructions and it can bond channels, essentially behaving as a double buffer.
DMA Controller FLow
SATA
I wrote a SATA hard drive controller a few years ago and I verified its functionality with a Virtex 6 FPGA. I posted the core on opencores nysa-sata. It works but it's difficult to use. I want to get the SATA controller to work on Artemis. I have a plan, it involves setting up the gigabit transceivers, configuring them to work with SATA and attaching the controller.
I've already started on this plan and it is progressing well:
Currently the GTP Transcievers seem to be alive. I wrote a small application that shows the transceivers are out of reset and the internal PLLs have locked on to the 150MHz SATA reference clocks and 100MHz PCIE reference clock. I am bringing the SATA core out of mothballs and adapting it to the wishbone bus. Last night I just finished the bare minimum port to wishbone so that I can make sure I can link up with the hard drive. Once this is finished I'll work on adapting the data interface to talk to the DMA controller.
Hardware Respin Required
Unfortunately, I found that a hardware respin is required of both Artemis and the host adapter board primarily because of connectors and I forgot to route a reset signal from the host control board to the main Artemis board. The new connectors will be more robust and the reset signal is trivial. Before I pull the trigger on an expensive fabrication and assembly I want to finish up the SATA checkout on this board. This will assure that I didn't make any mistakes while laying out the gigabit transceiver signals.
I'll post some pictures soon.
