I know very little about the arduino platform in general as well as hardware design, so this will be an adventure for me. I will be trying to modify code i find online and relying on the community to help me along. I am a developer/analyst by trade so i should be able to pick up the arduino language pretty quick. I am good at soldering and similar apsects of hardware development from some work i have done in the past on consoles.
At this point i need help picking out all the parts i will need. Below i have listed some parts i plan on using for the build. Need suggestions on if these will work together or not.
Can anyone help me replace the relays in my circuit with these (
http://www.mouser.com/ds/2/365/s216s02_e-184067.pdf) ???
I'm not sure what i need hardware wise and how to activate and deactivate the relay since its not a plug and play arduino board.
Thanks!!!
