New Circuit with Solid State Relay
01/02/2015 at 20:32 • 0 commentsIs this circuit safe the way i wired up the relay? I notice in alot of other circuit designs they use transistors but i can't see the reason why it is needed.
Ideas for Features
01/02/2015 at 17:35 • 0 comments- Potentiometer to control 'day' and 'night' light threshold instead of using hard coded value.
- Potentiometer to control Temp and Humidity thresholds instead of using hard coded values.
Parts Analysis and Schematic Help
01/02/2015 at 01:04 • 0 commentsHi Everyone, I have listed the parts i believe i will need to build my outlet.
My plan is to make 1 outlet humidity controlled, and one outlet temperature controlled. To achieve this i will cut the tabs connecting the outlets so i can wire each one separately to a relay. I can obtain both of the readings from the same sensor. I will also have a photo-resistor attached so i can determine 'day' and 'night'.
All i would like to be able to do is hard code some humidity and temperature values for a 'day' and 'night' setting that will trip the power outlet.
Am i on the right track parts wise? Can anyone help me build a schematic that i can wire up?
