I got this big robotic arm, filthy and rusty, with no controller. This project is about bringing it back to life and build a controller.
amigo tengo un escorbot igual a tu proyecto estoy atorado en el encoder cuantas vueltas da el disco del encoder por un grado espero y me puedas ayudar por favor
Lo siento , yo no hablo español ( Esto es usando el traductor de google )
I'm a High School teacher with a scorbot er V pro without the controller box.
I read your directions several times but get lost in a few places. Is it possible to get
directions in greater detail? Where did you get the 50 pin female connector?
Thank you
mcalhoun
Hi! I think the best way to make a conversation about the post is via the blogs' comments. If I wrote something which is not clear it is most likely you will not be the only one asking those questions :) - Just scroll down to to the bottom of the blog there's a comment section. If you prefer to discuss privately let me know and send me your email with a private message.About the 50 pins connector - Got it on ebay like all other items. Here's a link for example:http://www.ebay.com/itm/Audio-Video-DB50-50Pin-D-sub-Solder-Type-Female-Plug-Connector-Adapter-/390902034280?pt=LH_DefaultDomain_3&hash=item5b0393af68
Hello, can you reup the link to your project. I click the yellow link but it was crashed, thank you very much.
