case fitting
A project log for 3-buttonmouse with seperate wheel
convertion of an old SGI ps/2-mouse to a 3 button USB mouse with a separat non-clickable-scrollwheel
mclienmclien 03/24/2015 at 14:500 Comments
Next was cutting the side facing hole for the wheel:
Mainly by a dremel style tool and some marking before, but ended up just bigger than I liked.
And I hat to cut some parts of the metal (see above) and some material in the top case part to get it fitting.
strain relief for the cable done by a cable tie (original cable had it molded directly onto the cable, the USB one was done with some in molded clips):
