TLV2553 - CCS
11/02/2016 at 14:56 • 0 comments//Will Yates - NeoPixel_Simple #include <stdint.h> #include <stdbool.h> #include "inc/hw_gpio.h" #include "inc/hw_ints.h" #include "inc/hw_types.h" #include "inc/hw_memmap.h" #include "inc/hw_ssi.h" //#define PART_TM4C123GH6PM #include "driverlib/pin_map.h" #include "driverlib/qei.h" #include "driverlib/gpio.h" #include "driverlib/sysctl.h" #include "driverlib/rom.h" #include "driverlib/ssi.h" #include "driverlib/udma.h" //***************************************************************************** #define NUM_LED 6 #define LED_PORT GPIO_PORTA_BASE #define LED_PIN GPIO_PIN_7 #define TLV2553_PORT GPIO_PORTE_BASE #define TLV2553_CS GPIO_PIN_0 #define TLV2553_EOC GPIO_PIN_5 #define NRF24_PORT GPIO_PORTA_BASE #define NRF24_CSN GPIO_PIN_4 #define NRF24_CE GPIO_PIN_3 #define NRF24_IRQ GPIO_PIN_2 // TLV2553 Commands uint32_t chan_0 = 0b000000000000; // SELECT analog input channel 0 uint32_t chan_1 = 0b000100000000; // SELECT analog input channel 1 uint32_t chan_2 = 0b001000000000; // SELECT analog input channel 2 uint32_t chan_3 = 0b001100000000; // SELECT analog input channel 3 uint32_t chan_4 = 0b010000000000; // SELECT analog input channel 4 uint32_t chan_5 = 0b010100000000; // SELECT analog input channel 5 uint32_t chan_6 = 0b011000000000; // SELECT analog input channel 6 uint32_t chan_7 = 0b011100000000; // SELECT analog input channel 7 uint32_t chan_8 = 0b100000000000; // SELECT analog input channel 8 uint32_t chan_9 = 0b100100000000; // SELECT analog input channel 9 uint32_t chan_10 = 0b101000000000; // SELECT analog input channel 10 uint32_t test_1 = 0b101100000000; // SELECT TEST, Voltage = (VREF+ + VREF-)/2 uint32_t test_2 = 0b110000000000; // SELECT TEST, Voltage = REFM uint32_t test_3 = 0b110100000000; // SELECT TEST, Voltage = REFP uint32_t SW_PD = 0b111000000000; // SW POWERDOWN (analog + reference) uint8_t bit_8 = 0b000001000000; uint8_t bit_12 = 0b000000000000; uint8_t bit_16 = 0b000011000000; uint8_t msb = 0b000000000000; uint8_t lsb = 0b000000100000; uint8_t unipolar = 0b000000000000; uint8_t bipolar = 0b000000010000; //***************************************************************************** //***************************************************************************// //These two functions translate the 24bits for each LED to something that // //the WS2812b LEDs can understand. The datasheet is useless // // ________ // // |_____ '1' is a 800ns pulse then low (can be high forever) // // // // |________ '0' is a 400ns pulse (only key pulse lengt ) // // the only thing that really matters is that the high pulses dont overlap // //***************************************************************************// void Pixel_High() // function for sending a high pulse { GPIOPinWrite(LED_PORT, LED_PIN, LED_PIN); SysCtlDelay(3); //this needs to be the equv of 800ns (ish) GPIOPinWrite(LED_PORT, LED_PIN, 0x00); SysCtlDelay(3); //length of this doesn't really matter } void Pixel_Low() // function for sending the low pulse { // switching the pin on and off takes the proper amount of time GPIOPinWrite(LED_PORT, LED_PIN, LED_PIN); GPIOPinWrite(LED_PORT, LED_PIN, 0x00); SysCtlDelay(4); //length of this doesnt really matter } void clear_Ring() { //write the same value to all the LEDs int clear; int count; for(clear = 0; clear<NUM_LED; clear++){ //Green for (count = 0; count < 8; count++){ Pixel_Low(); } //Red for (count = 0; count < 8; count++){ Pixel_Low(); } //Blue for (count = 0; count < 8; count++){ Pixel_Low(); } } } void config_LED() { //Enable GPIO port SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // SYSCTL_PERIPH_GPIOF * blinky * while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOA)) // SYSCTL_PERIPH_GPIOF * blinky * { } GPIOPinTypeGPIOOutput(LED_PORT, LED_PIN); //reset pixels GPIOPinWrite(LED_PORT, LED_PIN, 0x00); clear_Ring(); SysCtlDelay(10000); } //***************************************************************************** //***************************************************************************// // This function is called to output the data onto the LEDs // // it calls the translate functions at the top // //***************************************************************************// void Pixel_GRB(char position, char color) { int clear; int count; switch(color){ case 'G': for(clear = 0; clear<position; clear++){ //Green for (count = 0; count < 8; count++){ Pixel_Low(); } //Red for (count = 0; count < 8; count++){ Pixel_Low(); } //Blue for (count = 0; count < 8; count++){ Pixel_Low(); } } for (count = 0; count < 8; count++){ Pixel_High(); } for (count = 0; count < 8; count++){ Pixel_Low(); } for (count = 0; count < 8; count++){ Pixel_Low(); } SysCtlDelay(1000); break; case 'R': for(clear = 0; clear<position; clear++){ //Green for (count = 0; count < 8; count++){ Pixel_Low(); } //Red for (count = 0; count < 8; count++){ Pixel_Low(); } //Blue for (count = 0; count < 8; count++){ Pixel_Low(); } } for (count = 0; count < 8; count++){ Pixel_Low(); } for (count = 0; count < 8; count++){ Pixel_High(); } for (count = 0; count < 8; count++){ Pixel_Low(); } SysCtlDelay(1000); break; case 'B': for(clear = 0; clear<position; clear++){ //Green for (count = 0; count < 8; count++){ Pixel_Low(); } //Red for (count = 0; count < 8; count++){ Pixel_Low(); } //Blue for (count = 0; count < 8; count++){ Pixel_Low(); } } for (count = 0; count < 8; count++){ Pixel_High(); } for (count = 0; count < 8; count++){ Pixel_Low(); } for (count = 0; count < 8; count++){ Pixel_Low(); } SysCtlDelay(1000); break; default: break; } } //***************************************************************************** void setup_ssi() { // put your setup code here, to run once: SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI2); SysCtlDelay(3); // EOC is on port A, but that is enabled when the LED's are enabled SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOB)) //MOSI PB_7, MISO PB_6, SCK PB_4 { } SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOE)) // TLV2553 CS PE_0 { } GPIOPinTypeGPIOOutput(TLV2553_PORT, TLV2553_CS); GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); GPIOPinTypeGPIOOutput(NRF24_PORT, NRF24_CE); GPIOPinTypeGPIOOutput(NRF24_PORT, NRF24_CSN); GPIOPinWrite(NRF24_PORT, NRF24_CE, NRF24_CE); GPIOPinWrite(NRF24_PORT, NRF24_CSN, NRF24_CSN); GPIOPinTypeGPIOInput(NRF24_PORT, TLV2553_EOC); GPIOPinConfigure(GPIO_PB4_SSI2CLK); //GPIOPinConfigure(GPIO_PB5_SSI2FSS); GPIOPinConfigure(GPIO_PB7_SSI2TX); GPIOPinConfigure(GPIO_PB6_SSI2RX); GPIOPinTypeSSI(GPIO_PORTB_BASE, GPIO_PIN_4); GPIOPinTypeSSI(GPIO_PORTB_BASE, GPIO_PIN_7); GPIOPinTypeSSI(GPIO_PORTB_BASE, GPIO_PIN_6); SSIIntClear(SSI2_BASE,SSI_TXEOT); //SSIDMAEnable(SSI2_BASE, SSI_DMA_RX); SSIConfigSetExpClk(SSI2_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 1000000, 12); // 15000000 7500000 SSIEnable(SSI2_BASE); } int main(void) { SysCtlDelay(10000000); //Set clock frequency ROM_SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); config_LED(); setup_ssi(); char pos = 0; while(1) { uint32_t val_null, val0, val1, val2, val3, val4, val5; while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_0| bit_12 | msb | unipolar)); //(chan_0| bit_12 | msb | unipolar) //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val_null); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_1| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val0); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_2| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val1); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_3| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val2); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_4| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val3); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_5| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val4); while (!(GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC)) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, 0x00); SSIDataPut(SSI2_BASE, (chan_6| bit_12 | msb | unipolar)); //SSIDataPut(SSI2_BASE, 0xFF); while (GPIOPinRead(NRF24_PORT, TLV2553_EOC) & TLV2553_EOC) { } GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); SSIDataGet(SSI2_BASE, &val5); //val0 = val0 << 4; //SSIDataGet(SSI2_BASE, &val0); //GPIOPinWrite(TLV2553_PORT, TLV2553_CS, TLV2553_CS); //SysCtlDelay(10000); /*val0 = 0; val1 = 0; val2 = 0; val3 = 0; val4 = 0; val5 = 0;*/ Pixel_GRB(pos, 'G'); pos += 1; if (pos > 7){ pos = 0; clear_Ring(); } /*pos = position / 332; // 153; if (rotatingdirection == 1){ Pixel_GRB(pos, 'G'); } else{ Pixel_GRB(pos, 'R'); }*/ } }
TLV2553 - Energia
11/02/2016 at 14:54 • 0 comments#include <SPI.h> #include "Arduino.h" const int dataReadyPin = PA_5; const int chipSelectPin = PE_0; // TLV2553 Commands uint16_t chan_0 = 0b000000000000; // SELECT analog input channel 0 uint16_t chan_1 = 0b000100000000; // SELECT analog input channel 1 uint16_t chan_2 = 0b001000000000; // SELECT analog input channel 2 uint16_t chan_3 = 0b001100000000; // SELECT analog input channel 3 uint16_t chan_4 = 0b010000000000; // SELECT analog input channel 4 uint16_t chan_5 = 0b010100000000; // SELECT analog input channel 5 uint16_t chan_6 = 0b011000000000; // SELECT analog input channel 6 uint16_t chan_7 = 0b011100000000; // SELECT analog input channel 7 uint16_t chan_8 = 0b100000000000; // SELECT analog input channel 8 uint16_t chan_9 = 0b100100000000; // SELECT analog input channel 9 uint16_t chan_10 = 0b101000000000; // SELECT analog input channel 10 uint16_t test_1 = 0b101100000000; // SELECT TEST, Voltage = (VREF+ + VREF-)/2 uint16_t test_2 = 0b110000000000; // SELECT TEST, Voltage = REFM uint16_t test_3 = 0b110100000000; // SELECT TEST, Voltage = REFP uint16_t SW_PD = 0b111000000000; // SW POWERDOWN (analog + reference) uint16_t bit_8 = 0b000001000000; // Configuration bits[3:2] {01: 8-bit output, uint16_t bit_12 = 0b000000000000; // 00: 12-bit output, uint16_t bit_16 = 0b000011000000; // 10: 12-bit output, // 11: 16:bit output} uint16_t msb = 0b000000000000; // Configuration bits[1] {0: MSB out first, uint16_t lsb = 0b000000100000; // 1: LSB out first} uint16_t unipolar = 0b000000000000; // Configuration bits[0] {0: Unipolar binary, uint16_t bipolar = 0b000000010000; // 1: Bipolar 2's complement} uint16_t val_null, val0, val1, val2, val3, val4, val5; SPIClass TLV2553(2); void setup() { Serial.begin(9600); TLV2553.begin(); //TLV2553.setDataMode(0); //TLV2553.setClockDivider(128); // initialize the data ready and chip select pins: pinMode(dataReadyPin, INPUT); pinMode(chipSelectPin, OUTPUT); digitalWrite(chipSelectPin, HIGH); } void loop() { while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val_null = TLV2553.transfer((chan_0 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val_null = (val_null << 4); val_null += TLV2553.transfer(0xF) >> 4; } digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val0 = TLV2553.transfer((chan_1 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val0 = (val0 << 4); val0 += TLV2553.transfer(0xF) >> 4; } Serial.print("A0: "); Serial.println(val0); digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val1 = TLV2553.transfer((chan_2 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val1 = (val1 << 4); val1 += TLV2553.transfer(0xF) >> 4; } Serial.print("A1: "); Serial.println(val1); digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val2 = TLV2553.transfer((chan_3 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val2 = (val2 << 4); val2 += TLV2553.transfer(0xF) >> 4; } Serial.print("A2: "); Serial.println(val2); digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val3 = TLV2553.transfer((chan_4 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val3 = (val3 << 4); val3 += TLV2553.transfer(0xF) >> 4; } Serial.print("A3: "); Serial.println(val3); digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val4 = TLV2553.transfer((chan_5 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val4 = (val4 << 4); val4 += TLV2553.transfer(0xF) >> 4; } Serial.print("A4: "); Serial.println(val4); digitalWrite(chipSelectPin, HIGH); while (!digitalRead(dataReadyPin)) { } digitalWrite(chipSelectPin, LOW); val5 = TLV2553.transfer((chan_6 | bit_12 | msb | unipolar) >> 4); while (digitalRead(dataReadyPin)){ val5 = (val5 << 4); val5 += TLV2553.transfer(0xF) >> 4; } Serial.print("A5: "); Serial.println(val5); digitalWrite(chipSelectPin, HIGH); Serial.println(); Serial.println(); Serial.println(); Serial.println(); Serial.println(); delay(1000); }
