• Kitchen Player update
    Matt Callow09/30/2015 at 00:50 0 comments
    Now with case!
    I've put the android phone into a small wooden case that I made on the laser cutter at RoboDino using the excellent tabbed box maker plugin for Inkscape
    Here's what's inside
    The phone is running:
    • Tasker
    • AutoSqueeze (tasker plugin)
    • SqueezePlayer
    • Headset Button Controller
    There are two buttons which are connected to the microphone input which allow control of the player.
    • Red button; single click = play/pause, double click = reset
    • Black button; single click = next track, double click = previous track
    Of course, it's also possible to control the player via any of the many Squeeze controller apps, or the web interface.
    Later I may look at exposing the screen to allow track info to be displayed. But for now, this is working great.
  • OpenELEC
    Matt Callow01/13/2015 at 22:21 0 comments
    I tried the OpenELEC build from here http://www.horus.com/~hias/tmp/openelec-wolfson/5.0-rc-cirrus/
    This supports the cirrus audio card out of the box, which is great. I had no problems using this for a quick test of XMBC/Kodi
    But, It's not really what I'm after. It's a specialised distribution for Kodi. I'd rather use a more general purpose distro (so that I can modify it later)
  • Linux Images
    Matt Callow01/10/2015 at 10:05 0 comments
    I tried a couple of Linux Images to see if they support the Cirrus Logic audio card.
    • Volumio 1.5 - does not support the audio card.
    # cat /dev/sndstat
    Sound Driver:3.8.1a-980706 (ALSA emulation code)
    Kernel: Linux volumio 3.12.26+ #702 PREEMPT Wed Aug 6 17:43:49 BST 2014 armv6l
    Config options: 0
    Installed drivers:
    Type 10: ALSA emulation
    Card config:
    bcm2835 ALSA
    Audio devices: NOT ENABLED IN CONFIG
    Synth devices: NOT ENABLED IN CONFIG
    Midi devices: NOT ENABLED IN CONFIG
    Timers:
    7: system timer
    Mixers: NOT ENABLED IN CONFIG
    • SqueezePlug_rpi_750 - does not support the audio card
    # cat /dev/sndstat
    Kernel: Linux lounge-audio 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l
    Config options: 0
    Installed drivers:
    Card config:
    bcm2835 ALSA
    Timers:
    7: system timer
    • cirrus_audio.img - Obviously this does support the audio card.
    # cat /dev/sndstat
    Kernel: Linux raspberrypi 3.12.33+ #12 PREEMPT Wed Dec 3 09:36:24 GMT 2014 armv6l
    Config options: 0
    Installed drivers:
    Card config:
    bcm2835 ALSA
    snd_rpi_wsp
    Timers:
    7: system timer
    Using Squeezelite, I can set up a simple squeezebox player
    Squeezelite v1.7, Copyright 2012-2015 Adrian Smith. See -t for license terms
    Modifying rc.local to run squeezelite at startup:
    pi@raspberrypi ~ $ cat /etc/rc.local
    #!/bin/sh -e
    # rc.local
    # This script is executed at the end of each multiuser runlevel.
    # Make sure that the script will "exit 0" on success or any other
    # value on error.
    # In order to enable or disable this script just change the execution
    # bits.
    # By default this script does nothing.
    # Print the IP address
    _IP=$(hostname -I) || true
    if [ "$_IP" ]; then
      printf "My IP address is %s\n" "$_IP"
    fi
    /home/pi/Reset_paths.sh
    /home/pi/Playback_to_Lineout.sh
    /home/pi/squeezelite-armv6hf  -o sysdefault:CARD=sndrpiwsp -n Lounge -z
    exit 0
  • Lounge Player
    Matt Callow01/08/2015 at 11:14 0 comments
    This one will be a connected to my Hi-Fi amp. It will be housed in a Reciva Internet Radio (https://radios.reciva.com/) case:
    but with the internals
    replaced with a Raspberry Pi Model A+, and a Cirrus Logic Audio card
    I'll use squeezelite (https://code.google.com/p/squeezelite/) as the player. First, I need to get the sound card working.
    I'm going to look at the piCorePlayer image(https://sites.google.com/site/picoreplayer/) to see if that supports the sound card (I expect it doesn't)
    Failing that, I'll try the 'official' cirrus_audio.img from Element14.
  • Kitchen Player
    Matt Callow01/08/2015 at 01:49 0 comments
    My player for the kitchen consists of an old HTC wildfire phone running SqueezePlayer and a pair of Altec Lansing amplified speakers. This has been working well for a week or so. Since I already had the phone and the speakers spare, the total cost so far is A$5.29.
    I'd like to add some local control buttons. I'm thinking of wiring up 3 buttons as per this article http://hackaday.com/2010/11/03/patching-into-android-music-control/ and then using Tasker and the autosqueeze plugin to control the player. I may also need Headset Droid to capture the button presses.
