Linux Images
A project log for Streaming Media Players
Project to make a number of streaming media players for my house
matt-callowMatt Callow 01/10/2015 at 10:050 Comments
I tried a couple of Linux Images to see if they support the Cirrus Logic audio card.
# cat /dev/sndstat
Sound Driver:3.8.1a-980706 (ALSA emulation code)
Kernel: Linux volumio 3.12.26+ #702 PREEMPT Wed Aug 6 17:43:49 BST 2014 armv6l
Config options: 0
Installed drivers:
Type 10: ALSA emulation
Card config:
bcm2835 ALSA
Audio devices: NOT ENABLED IN CONFIG
Synth devices: NOT ENABLED IN CONFIG
Midi devices: NOT ENABLED IN CONFIG
Timers:
7: system timer
Mixers: NOT ENABLED IN CONFIG
# cat /dev/sndstat
Kernel: Linux lounge-audio 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l
Config options: 0
Installed drivers:
Card config:
bcm2835 ALSA
Timers:
7: system timer
# cat /dev/sndstat
Kernel: Linux raspberrypi 3.12.33+ #12 PREEMPT Wed Dec 3 09:36:24 GMT 2014 armv6l
Config options: 0
Installed drivers:
Card config:
bcm2835 ALSA
snd_rpi_wsp
Timers:
7: system timer
Using Squeezelite, I can set up a simple squeezebox player
Squeezelite v1.7, Copyright 2012-2015 Adrian Smith. See -t for license terms
Modifying rc.local to run squeezelite at startup:
pi@raspberrypi ~ $ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
/home/pi/Reset_paths.sh
/home/pi/Playback_to_Lineout.sh
/home/pi/squeezelite-armv6hf  -o sysdefault:CARD=sndrpiwsp -n Lounge -z
exit 0
