Simple Sketch to transfer 433Mhz Datastream to Uart/USI only needs Attiny85
#include <RCSwitch.h> RCSwitch mySwitch = RCSwitch(); // Set your baud rate and number of stop bits here #define BAUDRATE 9600 #define STOPBITS 1 #define CYCLES_PER_BIT ( (F_CPU) / (BAUDRATE) ) #if (CYCLES_PER_BIT > 255) #define DIVISOR 8 #define CLOCKSELECT 2 #else #define DIVISOR 1 #define CLOCKSELECT 1 #endif #define FULL_BIT_TICKS ( (CYCLES_PER_BIT) / (DIVISOR) ) enum USISERIAL_SEND_STATE { AVAILABLE, FIRST, SECOND }; static volatile enum USISERIAL_SEND_STATE usiserial_send_state = AVAILABLE; static inline enum USISERIAL_SEND_STATE usiserial_send_get_state(void) { return usiserial_send_state; } static inline void usiserial_send_set_state(enum USISERIAL_SEND_STATE state) { usiserial_send_state = state; } bool usiserial_send_available() { return usiserial_send_get_state() == AVAILABLE; } // Transmit data persistent between USI OVF interrupts static volatile uint8_t usiserial_tx_data; static inline uint8_t usiserial_get_tx_data(void) { return usiserial_tx_data; } static inline void usiserial_set_tx_data(uint8_t tx_data) { usiserial_tx_data = tx_data; } static uint8_t reverse_byte (uint8_t x) { x = ((x >> 1) & 0x55) | ((x << 1) & 0xaa); x = ((x >> 2) & 0x33) | ((x << 2) & 0xcc); x = ((x >> 4) & 0x0f) | ((x << 4) & 0xf0); return x; } void usiserial_send_byte(uint8_t data) { while (usiserial_send_get_state() != AVAILABLE) { // Spin until we finish sending previous packet }; usiserial_send_set_state(FIRST); usiserial_set_tx_data(reverse_byte(data)); TCCR1 = 0; TCCR1 |= (1 << CTC1); // CTC mode TCCR1 |= (0 << CS10); // Set prescaler to clk or clk /8 TCCR1 |= (0 << CS11); TCCR1 |= (1 << CS12); TCCR1 |= (0 << CS13); GTCCR |= (1 << PSR1); TIMSK |= (1 << OCIE1A); OCR1C = FULL_BIT_TICKS; // Trigger every full bit width TCNT1 = 0; // Count up from 0 // Configure USI to send high start bit and 7 bits of data USIDR = 0x00 | // Start bit (low) usiserial_get_tx_data() >> 1; // followed by first 7 bits of serial data USICR = (1 << USIOIE) | // Enable USI Counter OVF interrupt. (0 << USIWM1) | (1 << USIWM0) | // Select three wire mode to ensure USI written to PB1 (0 << USICS1) | (0 << USICS0) | (0 << USICLK); // Select Timer0 Compare match as USI Clock source. DDRB |= (1 << PB1); // Configure USI_DO as output. USISR = 1 << USIOIF | // Clear USI overflow interrupt flag (16 - 8); // and set USI counter to count 8 bits } ISR (TIM1_COMPA_vect) { // Start bit (low) // followed by first 7 bits of serial data USICR |= (1 << USICLK); }// USI overflow interrupt indicates we have sent a buffer ISR (USI_OVF_vect) { if (usiserial_send_get_state() == FIRST) { usiserial_send_set_state(SECOND); USIDR = usiserial_get_tx_data() << 7 // Send last 1 bit of data | 0x7F; // and stop bits (high) USISR = 1 << USIOIF | // Clear USI overflow interrupt flag (16 - (1 + (STOPBITS))); // Set USI counter to send last data bit and stop bits } else { PORTB |= 1 << PB1; // Ensure output is high DDRB |= (1 << PB1); // Configure USI_DO as output. USICR = 0; // Disable USI. USISR |= 1 << USIOIF; // clear interrupt flag TCCR1 = 0; usiserial_send_set_state(AVAILABLE); } } void setup() { TCCR1 = 0; mySwitch.enableReceive(0); pinMode(1, HIGH); // Configure USI_DO as output. digitalWrite(1, HIGH); // Ensure serial output is high when idle } String test = ""; long temp = 0; void loop() { if (mySwitch.available()) { test = ""; test += String(mySwitch.getReceivedValue()); test += "\n"; char text [test.length()]; test.toCharArray(text, test.length()) ; uint8_t len = sizeof(text) - 1; for (uint8_t i = 0; i < 8; i++) { while (!usiserial_send_available()) { // Wait for last send to complete } usiserial_send_byte(text[i]); } mySwitch.resetAvailable(); } }
View all instructions
Alex Hiam
Keith
Ed0
Yes, delete it Cancel
You are about to report the project "attiny RC-switch to Serial Bridge", please tell us the reason.
