some pictures of the misery
A project log for R8-D8 - a distant relative of R2-D2
a 12cm radius, 3d printed R2-D2 with some motors, servos and blinky stuff that follows lines, persons or just drives around via bluetooth
davedarkodavedarko 02/18/2015 at 12:180 Comments
Here's R8 upside down on his neck, with the controller connected to the arduino and the motors over a Molex connector I harvested from my PSU build.
A close up of the "flying wire" perfboard hot-glue mess. Yes, the power cable is twisted, but only the colors, since GND is on the first pin of the pin header.
Quite helpful, a sheet of paper telling which pins from the arduino are connected to what or to what purpose.
