Android and USB DAC
A project log for USB DAC with amplifier
A USB DAC with a 3-W x 2 amplifier
andreas-dahlbergAndreas Dahlberg 01/06/2015 at 21:520 Comments
Found out today that support for USB audio peripherals was added in Android Lollipop. Tested the USB DAC with my Nexus 5 and it worked perfectly! The only downside is that a external power supply is needed when volume is increased.
Android USB Audio
