1Step 1
Setup
Materials
- Inserting your USB into the breakout board socket, and then mount it to your breadboard.
- You will then take your potentiometer knob and attach the wires to the breadboard.
- With your potentiometer's pin wires directly facing you, take the far left wire and insert it into the VCC on breadboard.
- Next, take the middle wire and insert it into D-.
- Lastly, you will take the far right wire and insert it into the GND.
You are now fully setup! Please note that we have modified our potentiometer by encasing it with a plastic Comingle knob. We did this so we could turn the shaft of the potentiometer in an easier fashion.
2Step 2
Upload Code
Plug in the Mod's USB to your computer, and click "Run on Arduino" in the embedded sketch below. This program will let the Mod detect and respond to your potentiometer.
