Hackaday.io Hackaday.io
Sign up Log in
Frienduino
A single layer all through hole PCB layout for a simple Arduino clone with USB!
jgeisler0303jgeisler0303
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
2 comments
51 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.5k
2
51
12
Team (1)
  • jgeisler0303jgeisler0303
Join this project's team
  • Board schematic and layout and instructions
hardware
completed project
arduino pic usb 16f1454
This project was created on 01/14/2015 and last updated 11 years ago.
Description
The Frienduino is an Arduino clone you can make for a friend once you have any kind of Arduino and some soldering skill. The board is easy to make (single sided) and easy to solder (only through hole components). It has everything to get started yet it is cheap and simple because it saves on stuff the novice doesn't need (separate power supply and 3.3V regulator). IMHO, what made the Arduino so popular is its USB connectivity. This lowers the entry barrier to near zero. No messing around with programmers, no legacy serial port required. Alas, most of the many many Arduino clones out there lack this key feature. I guess the reason for this is that, until now, all USB to serial adapters were not available as a through hole component, thus discouraging the novice to build a "true to the spirit" clone on their own.
Components
  • 1 × BOM at German distributer: https://secure.reichelt.de/index.html?&ACTION=20&AWKID=1013176&PROVID=2084
Project Logs
Collapse
  • Ready and tested
    jgeisler0303 • 06/06/2015 at 19:27 • 0 comments
    I have now had a first batch of PCBs made at Seeedstudio. The Gerbers are in the repo @github. And here is a ready to order Seeedstudio project.
    Flashing of the PIC has now become even more easy with the special low voltage programming version of ardpicprog.
    Also added Windows driver .inf file for the USB virtual serial port supplied by the PIC.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
zoobab wrote 04/09/2018 at 11:04 • point
Problem is the USB chip you use requires (a PIC in this case) a non-free compiler. I would replace it with a ch340g which is also quite easy to solder.
Stephen Covrig wrote 04/17/2023 at 22:04 • point
check this out, you can program the PIC with an Arduino
https://github.com/jgeisler0303/ardpicprog
A Small Board with 2kb USB Micronucleus Bootloader Based on Attiny85 with USB Slot.
Project Owner Contributor
Arduino Tiny Relaisboard
schuppSchupp
You'll learn how to construct a Mini USB Arduino.
How to Construct a Mini USB Arduino
silcios-labSilícios Lab
Pocket sized ARDUINO UNO Clone
ShrinkDuino UNO
lexcisLexcis
Maybe the world first BLE circuit without PCB?
Dead-bug BLE LED blinky
deqingdeqing
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Frienduino", please tell us the reason.
Send message
Remove Member
