Body34.stl
The battery cage that holds the AA cells in place.
Standard Tesselated Geometry - 197.15 kB - 01/22/2018 at 05:24
Download
batterystalk.stl
The thin part of the battery pack that extends into the drill body.
Standard Tesselated Geometry - 438.46 kB - 01/22/2018 at 05:24
Download
cap.stl
The very tip of the battery pack. This cap covers the contacts that relay current to the battery. Hosts a hole through which a 19mm M3 bolt connects to the batterystalk. The hole has a small support plug which is to be printed against the bed, and snapped off before use.
Standard Tesselated Geometry - 139.83 kB - 01/22/2018 at 05:24
Download
battbody.stl
The main chassis of the battery pack.
Standard Tesselated Geometry - 337.58 kB - 01/22/2018 at 05:24
Download
rearbar.stl
A thinner spacer bar to help maintain proper spacing when tightening the batterystalk to the battbody. This will go near the battery door (celllid.stl)
Standard Tesselated Geometry - 39.34 kB - 01/22/2018 at 05:24
Download
capplug.stl
A small spacer that goes at the tip of the battery stalk which holds the contacts in the proper place.
Standard Tesselated Geometry - 84.85 kB - 01/22/2018 at 05:24
Download
frontbar.stl
A fatter spacer bar to maintain proper spacing when tightening the batterystalk to the battbody. This will go furthest from the battery door, near the rounded part of the battery pack
Standard Tesselated Geometry - 39.93 kB - 01/22/2018 at 05:24
Download
Body35.stl
The internal lid for the AA battery cage. This hosts some spring contacts that touch the AA batteries.
Standard Tesselated Geometry - 61.21 kB - 01/22/2018 at 05:24
Download
celllid.stl
The lid that holds the AA cells in the battery pack. This slides on and off and is held by friction. Will hold 2 small copper rods as contacts against the AA batteries.
Standard Tesselated Geometry - 9.46 kB - 01/22/2018 at 05:24
Download
Body36.stl
A spacer to stop the AA cells from moving too much.
Standard Tesselated Geometry - 1.64 kB - 01/22/2018 at 05:24
Download
