First prototype
A project log for Garage Parking Sensor
Ultrasonic parking sensor for garage mounting
rasmus-ljungmann-pedersenRasmus Ljungmann Pedersen 01/20/2015 at 20:250 Comments
As you surely can see, this is still very much a work in progress. None the less, if supplied with permanent power from an outlet, it could be used as is. Running from batteries won't last long at the moment.
Possible power usage improvements include:
Other improvements would be a custom PBC and a custom casing.
