I have a random ADC from TI, a 140*32 VFD from Noritake, a composite output camera, and a Mojo v3, so I'm going to see what the best-looking thing I can make out of it will be.
As I need a high refresh rate to display interesting information, and I want to learn how to implement something in Verilog that isn't an RS232 port, I'm using the VFD's parallel port. I have heard that these VFDs can manage 60-70Hz refresh rates so I'll try pushing the limits with animation. As a rough calculation, the data I'll be sending at 60Hz over each of the 8 parallel ports is
which is certainly manageable with a 50MHz Spartan6.
