PCB Motor
A smaller and cheaper open source brushless motor.
My open source PCB motor is a smaller, cheaper and easier to assemble micro brushless motor.
What unique about this motor design is that the stator is printed on a 4-layer PCB board. The six stator poles are spiral traces wounded in a star configuration. Although these coils produce less torque compared to an iron core stator, the motor is still suitable for high-speed applications.
The current prototype has a 3d printed rotor with a 16mm diameter.
My PCB-Motor is made from a 6-pole stator printed on a 4-layer PCB and a 4-pole 3d printed rotor. Its has an outer diameter of 16mm and is rated at 1 watt.
I had this idea when I was trying to design a small compact drone. The PCB motor is much cheaper than other micro brushless motors and also easier to assemble. My goal is to make the rotor part of the BOM and mounted just like any other component on a PCB.
VIDEO
PCB Motor V1.rar
Gerber Files and STL file of the first PCB-Motor prototype.
RAR Archive - 194.17 kB - 02/07/2018 at 22:54
Download
  • 1 × 3D Printed Rotor
  • 1 × PCB Stator
  • 4 × Magnets (5mm diameter x 1mm thick)
  • 1 × Shaft (1.5mm diameter)
  • 1 × SMF681X-ZZ Bearing
  • Torque
    Carl Bugeja3 days ago 0 comments
    So torque is the biggest weakness of my tiny PCB motor. This was measured it to be 0.9gcm.
    But it is something that can be improved. These are three ways how I tried to improve it:
    • Double Rotor - Some people in the comments suggested to try and use a double rotor. This will increase the magnetic field produced by the neodymium magnets and therefore will also increase the motor's torque. But in practice this was not the case and  it barely had any effect. The measured torque was 0.9gcm (the same as with one rotor).
    • Ferrite Sheet - This was used as a core to increase the strength of the magnetic field inside the printed windings. Two different shaped cores were tested. The uncut one gave a higher torque value and has increased it from 0.9gcm to 1.5gcm. The only down side of this is that It has also increased the pcb's temperature from 70°C to 90°C due to eddy current losses.
    • Delta configuration - Other simple way to increase the torque is by changing the configuration to a delta winding. This way the coils will be powered with a higher voltage, so it will also increases the torque and temperature (hopefully not by much). This approach was not tested yet.
    Check out the full tested video:
  • Update
    Carl Bugeja06/08/2018 at 22:35 0 comments
    A quick update on my PCB Motor prototype:
    • Dimensions - 16x17x5mm (excluding the shaft)
    • Weight - 1.6grams
    • PCB Stator - 6 Poles connected in a delta configuration, with 40 turns each with 4/4mil traces.
    • 3D Printed Rotor - 4 Poles
    • Bearings - Stainless Steel
    • Phase Resistance - 19.3 ohms
    • Power Rating - 1W
    • Maximum Temperature - 70°C (at 5V)
    • Maximum Torque - 0.9 g.cm
    Improvements that I'm planning to test:
    • Torque
    • Temperature
    • Increase the winding's magnetic field strength by reducing the PCB thickness
    • Use ceramic instead of stainless steel bearings to reduce friction
    • Experiment with different trace winding's clearance and thickness. Increasing it to 5/5mil from 4/4mil will reduce the pcb's cost at low volumes. However, this would also enlarge the motor's diameter to reach same parameter's of the 40turn 4/4mil coil.
  • Thermal Testing
    Carl Bugeja05/27/2018 at 21:21 0 comments
    How hot is my pcb motor getting? With a direct 5v supply on the windings it reached a maximum of 70°C after 13 minutes of continuous voltage.
    How to improve this? For the next prototype I'm going to use more vias and a copper plane on all four layers to conduct heat on a larger area.
  • Closed-loop Control
    Carl Bugeja03/27/2018 at 20:09 0 comments
    My plan for speed controlling the PCB Motor was to implement a sensorless back-emf speed controller, which works just like every other brushless ESC. It measures the time it takes to detect the zero-crossing point from the under-driven phase, and adjust the commutation waveforms according. However, during testing the back-emf generated in the windings of the PCB motor was a little weak.
    Plan-B is to use a hall sensor to implement the closed loop speed controller. This will be a little more pricey but will also include positional sensing.
  • New Rotor
    Carl Bugeja03/05/2018 at 00:33 1 comment
    This is my new 3D printed rotor prototype with a snap-hook shaft and press-fit circular magnets!
    Unlike the old prototype, the new rotor has a uniform magnetic field across its whole area.
    The metallic shaft was also eliminated. Instead it was made part of the 3D rotor model, At the end of this shaft are two snap-hooks that lock the rotor inside the bearing.
    This feature makes the brushless PCB motor cheaper and very easy to assemble!
  • PCB Motor - Explained
    Carl Bugeja02/25/2018 at 13:58 0 comments
    This video briefly describes how my brushless PCB motor works.
  • Open Source Files
    Carl Bugeja02/07/2018 at 23:09 0 comments
    The gerber files and STL file for the first PCB-Motor prototype are now available for download.
    If you don't have access to a 3d printter, you can purchase the rotor here: https://www.shapeways.com/product/GD48BQX8D/pcb-motor-4-pole-16mm-rotor?optionId=64748243&li=shop-inventory
  • How I design the PCB stator
    Carl Bugeja01/27/2018 at 09:37 1 comment
    This project started with me trying to design a small cheap drone. Dc brushed motors are typically used for micro-drone designs since they are much cheaper than brushless motors. But these motors were not compact enough for my application. So I started looking into ways to make a custom brushless motors which is smaller, cheaper and easier to manufacture.
    A normal outrunner brushless motor is made from a stator, a rotor and a shaft that connects the two via a bearing. Its stator has windings around an iron core to rotate the magnets on the rotor. The high magnetic permeability of the iron core creates a strong magnetic field around each coil, which improves the motor's torque strength.
    I had this idea of making the stator embeeded in the PCB itself. My only concern was that to make it small, it had to be core-less. I decided to try it out and see if it had enough strength to rotate a small propeller (spoilers - it did).
    PCB stator vs ADH30S's stator
    I wanted the first prototype to have the best possible chance of working, while still being as small as possible. So I set the trace spacing and thickness to 0.1mm and the via's drill size to 0.15mm. Although these parameters would increase the manufacturing costs of the PCB, it was the safest starting point for my PCB motor design.
    I decided to make my motor have a 4-layer 6-pole stator, to have as many windings as possible. The star type stator configuration was used to limit the phase voltage, hence limiting the overall power of the motor (more power = more heating in stator coils).
    Gerber Files of the 4-layer Stator
    There is alot more of experimentation and testing that I need to do before trying to integrate it with a drone. I want to find the best "turns-to-size" ratio and how does that effect the motor's torque. I would also like to test the delta configuration and a PCB-motor with a 9-pole stator.
  • Propeller Test!
    Carl Bugeja01/24/2018 at 20:34 0 comments
    Testing my brushless PCB-Motor with RX2535W propeller.
  • Dimensions
    Carl Bugeja01/23/2018 at 18:46 0 comments
    The first PCB Motor prototype measures 16x17x5mm (excluding the shaft) and weighs 1.5 grams.
View all 12 project logs
  • 1
    Step 1
    Its this simple:
View all instructions
Calrexreid wrote 05/31/2018 at 14:40 point
Fantastic project - Perfect for solving a headache I had in my project - Thank you. I have ordered a few off OSHPark.. :) ill upload project when further down the road.
I am currently using them in a prototype that will be a fair bit larger than the final version of my project. I am unfamiliar with the limits of PCB manufacture and wonder if you can enlighten me? Do you think it could be made any smaller? In terms of Diameter? Less windings, thinner traces? Looking to get it down to 10mm so about 35% smaller. Obvious huge reduction in power etc.. but still functional? I thought to ask you as you may have already experimented with further miniaturisation and come across some limitations. Be great to get your thoughts! Thank you again for a great concept!
Carl Bugeja wrote 05/31/2018 at 21:25 point
Hi! It is very difficult to make it smaller than 16mm. In my prototypye I am using 4/4mil traces on a 4 layer board. I have around 10 turns on each layer adding up to a total of 40 turns.  I don't recommend going much lower than 40turns with 4/4mil, as these would reduce the phase resistance and increase the overall temperature of the pcb. The only remaining options to reduce the area would be either use smaller manufacturing traces and clearance (which would be much more expensive for a supplier to manufacturer) or increasing the number of layers. However, you need to be careful as increasing the layer would mean you have to leave a larger area in the middle of the coil for more vias.
Calrexreid wrote 06/01/2018 at 08:33 point
That is really useful to know, thank you Carl for your time and considered response. Very appreciated. I may look at 2/2 mil traces in the future if the prototype has any promise. In the meantime though I am very happy with the boards, that have just arrived!
alexw wrote 04/01/2018 at 08:08 point
Awesome project, it'll be great to see people using this!
Carl Bugeja wrote 05/04/2018 at 19:39 point
Thanks!
Ron wrote 03/28/2018 at 18:27 point
I was curious, where did you get the semicircular magnets from?
ehsan wrote 04/23/2018 at 21:10 point
I'm quite interested in this as well. Can't find anything of the same size. Any help is highly appreciated.
Hi :) Those were both custom from a manufacture I found on alibaba.com
jkocurek wrote 5 days ago point
How much for how many units?
Anil wrote 03/18/2018 at 02:35 point
Does this DC motor need a hall effect sensor to control it? What controls the sequencing of the windings like a usual brushless DC motor?
Carl Bugeja wrote 03/27/2018 at 20:16 point
My plan was to use a sensorless back-emf speed controller, however the measured back-emf was too weak to implement this. I'm now working on a prototype with hall sensor for speed and position control.
Anil wrote 03/29/2018 at 21:22 point
Yeah, that makes sense. Would be cool to get the PCB coils strong enough to go sensorless. I bet you could do it if you made the coil strips longer.
bobricius wrote 03/12/2018 at 16:04 point
great project, I am trying stepper motor as direct drive wheel for robot https://youtu.be/78K-oa2GHU4 instead of printed rotor I am using PCB rotor (3 layers of 1mm PCB and 5x3mm magnets) https://oshpark.com/shared_projects/V5EU4Lhf
Carl Bugeja wrote 03/12/2018 at 18:12 point
cool :) just make sure you have enough torque to rotate the wheels and move the robot
Peter McCloud wrote 02/08/2018 at 06:55 point
This is really cool. Thank you for sharing the Gerber files!
I'm interested in using this approach for building an axial flux generator. I can't find any existing designs that fit my needs and making PCBs seems easier than hand windng coils and potting them.  For those of us new to the PCB design world, would you mind providing an outline of the tools you used to design your PCB?
Carl Bugeja wrote 02/10/2018 at 09:25 point
Hi Peter! I used a CAD tool to draw the spiral coil windings for each layer. These layers were saved as a dxf file and then imported into a PCB design software as different copper layers.
helge wrote 02/07/2018 at 23:08 point
maybe ferrite foil in the back would be beneficial?
http://katalog.we-online.de/en/pbs/WE-FSFS and the like.
crazzzik wrote 01/30/2018 at 03:32 point
Do you have a power requirement for your drone?
James Newton wrote 01/29/2018 at 04:36 point
I'm curious how you are driving the motor? Is it just from the Digital IO pins on the Arduino? Or are there transistors, FETs, etc...
Carl Bugeja wrote 01/29/2018 at 21:52 point
Hi I'm currently using the STSPIN230 3-phase driver (availble on the X-NUCLEO-IHM11M1 dev board). I am then driving it with a dPic microcontroller.
Moldovanu Ionut wrote 01/26/2018 at 10:22 point
Hello , can you please release the pcb design files , or just draw a schematic of the coils and all the details?
Carl Bugeja wrote 02/07/2018 at 22:56 point
Hi! The files are now available for download
oshpark wrote 01/26/2018 at 05:38 point
great idea!
Carl Bugeja wrote 01/27/2018 at 06:59 point
Robert Mateja wrote 01/25/2018 at 09:04 point
I that HP MultiJet material or your own print for black rotor ?
Carl Bugeja wrote 01/25/2018 at 11:26 point
Hi i have 3d printed from shapeways
agarner3 wrote 01/25/2018 at 07:37 point
This is such a great idea. I agree it would work better with a different stator/magnet configuration. It would be interesting to see how torque and kv would be affected with different thickness traces. And how much more output and balance you could achieve with two magnet sets sandwiching the stator.
I can see a revolution in quad copters coming on. It would be amazing to see this on the crazyflie (open source)  quad
Carl Bugeja wrote 01/25/2018 at 11:30 point
Sure :) a rotor combined with propeller is coming soon
Thomas Daede wrote 01/25/2018 at 04:07 point
This is neat! I would like to try to build my own, and also have some things I'd like to try to improve the design:
Most axial flux motors have magnets on both sides of the stator. The purpose of this is to not just to fit in more magnet, but to make sure all of the magnetic flux passes perpendicularly through the stator - with your current design, some of it wraps around the magnets and doesn't even make it through the PCB. Likewise, on the rotors behind the magnets is iron, to complete the magnetic circuit and get better utilization of the magnets. Iron-filled plastic could substitute here, though it's less important and just using beefier magnets might also be OK.
The downside of facing rotors is there is a huge amount of force between them. You'll either need strong 3D printed parts, or attach them on the outer diameter, running the wires through a non-rotating axle.
For bigger motors, you can get a better winding factor with an 8/9 or 10/12 arrangement. If you don't already know about it, there's a nice winding calculator here: https://www.emetor.com/edit/windings/
Note that coreless axial flux motors like this can be quite efficient. You might find some inspiration from the CSIRO design often used by solar cars. http://www.ata.org.au/wp-content/uploads/marand_high_efficiency_motor.pdf
Carl Bugeja wrote 01/25/2018 at 17:42 point
Hi Thomas! Thanks for the tips! For the second prototype I have order semicircular magnets so that all magnetic flux pass through the stator, just like you suggested :) stay tuned for the update
adria.junyent-ferre wrote 01/29/2018 at 09:02 point
Excellent feedback. Btw, I tried the iron-filled plastic myself  some time ago when I wanted to make a linear actuator with 3d-printed parts and the results were quite disappointing. The effective permeability one gets ends up being around 2, which is quite disappointing (https://hackaday.io/project/11082-measuring-blackmagic3ds-ferromagnetic-filament).
Daren Schwenke wrote 01/24/2018 at 21:57 point
Thin out your rotor and add a second stator above.  Gives you your second bearing mount, doubles your output torque, and will probably be more stable as both sides will push/pull the rotor at the same time.
Carl Bugeja wrote 01/25/2018 at 17:36 point
Hi Daren cool idea! I would consider adding another rotor to have magnets on both sides rather than adding another stator. This will definitely help increase the torque,
Daren Schwenke wrote 01/25/2018 at 18:11 point
Torque comes from flux density.  There are a couple ways to increase that.
Simplest way is to use a core material.  This compresses your field lines for your electromagnet yielding higher flux density, at the expense of additional inductance.  But that doesn't really fit here.
Next simplest would be to compress/redirect the field lines from your permanent magnets back towards your electromagnets.  This is usually accomplished by backing them with iron. A washer or the bell from a fridge magnet might do it.
So where I was going with the second stator is related to the latter.  Besides doubling the flux density of the electromagnets, you are also confining the stray back field lines from your rotor magnets.  Of course I could be full of it, but it works in my head..
CWC wrote 01/24/2018 at 21:42 point
Hello Carl. Congratulations on your excellent work! Please let us know if you plan to sell your motors. I like the idea of putting the stator on the ESC PCB.
Carl Bugeja wrote 01/25/2018 at 11:32 point
Hi :) i will release open source parts very soon so you can build your own
spillikinaerospace wrote 01/24/2018 at 21:26 point
Hi Carl excellent work! one question: why didn't you make the rotor from a PCB? it seems to me that would be better than 3d printing.
Prof. Fartsparkle wrote 01/24/2018 at 21:30 point
Good question, I mean air flow would be an obvious reason but at this stage I doubt that would be much of an issue.
Carl Bugeja wrote 01/24/2018 at 21:33 point
Hi! the rotor needs to hold the magnets in place that's why its 3d-printed. But make a pcb on top of the rotor is certainly possible. The only problem would be passing signals and giving power to that board.. But with a little imagination I think it can be solved :)
alexwhittemore wrote 01/24/2018 at 22:53 point
This was my question as well. I think what he means is to pocket-mill recesses in a similarly sized PCB to fit the magnets, making a roughly equivalent structure from FR4 instead of plastic. An FR4 magnet carrier would ultimately be stronger than the plastic version, and practical to fabricate since it doesn't require any complicated 3D geometry, only standard controlled-depth milling. And really, you wouldn't necessarily need that either - you could use through-routes on one PCB and leave it at that with the magnets glued in by the sides, or glue the milled PCB to a flat one of the same diameter to make fake pocket mills. Making such a through-milled magnet carrier would also enable Daren's idea above of adding a second stator to double torque.
Carl Bugeja wrote 01/25/2018 at 17:29 point
The problem with a pcb rotor is actually keeping the magnets in place .. its certainly possible to have them press fitted inside but having the rotor spinning at high speed it would be safer to have a cover over them..
Sean Weppner wrote 01/24/2018 at 21:13 point
Would be cool to see this type of approach applied to creating a micro linear actuator
Carl Bugeja wrote 01/24/2018 at 21:38 point
Hi Sean a micro linear actuator seems feasible with this technology.. However it would have a weak torque since it don't have a metalic core.
eekster wrote 01/24/2018 at 19:08 point
I'll buy ten of them! That or make the cad files and bill of materials available, perhaps? Please?
openube wrote 01/24/2018 at 21:23 point
I second this. I'll buy or BOM please?
Carl Bugeja wrote 01/24/2018 at 21:41 point
Hi! Thanks for your kind comments :)  I think I will eventually open source this design.. It just needs a little more testing
ActualDragon wrote 01/23/2018 at 23:32 point
It almost needs another row of headers on the other side, just for support. It might be helpful
Carl Bugeja wrote 01/24/2018 at 06:59 point
Hi 🙂 the headers are just a temporary solution. My plan is to put the stator on the esc pcb.
Carl Bugeja wrote 01/24/2018 at 07:02 point
This would make the whole setup light and more compact
ActualDragon wrote 01/24/2018 at 10:50 point
could you put the headers on the other side, then slide the esc under and solder it? that would be sweet
