Update
A project log for PCB Motor
A smaller and cheaper open source brushless motor
carl-bugejaCarl Bugeja 06/08/2018 at 22:351 Comment
A quick update on my PCB Motor prototype:
Improvements that I'm planning to test:
James Newton wrote 07/13/2018 at 23:37 point
Larger windings would also reduce heat / allow for higher voltages and the larger rotor should produce more torque.
