Arduino Bowel Gauge
Measure Calories Leaving The Body
In our current climate of caloric dissemination, few observe before and after exhumation of waste. To clarify, using a resistance sensor and an Arduino, we have hacked your bowels.
[Notation] The resistance sensor observed in the following multimedia is a first version testing sensor. Affixing it to a constantly drenched porcelain surface proved difficult and was temporarily remedied with Gorilla Tape.
A brass valve was added to the bowl fill line extending from the fill valve as to regulate the water level with in the bowl. Typical specs fill water to crest the rear siphon allowing waste to displace water in to the drainage line as to prevent over flow.
HackADay "Skull and Wrenches" logo used with(out) permission by HackADay.com
HackADay - We Asked For It Arduino Bowel Gauge
Element14 - 10 Awesome Arduino Projects
  • 1 × Arduino Uno
  • 1 × LCD Display
  • 1 × 100K R
  • 1 × 1K R
  • 1 × 0.1 uf C
View all 7 components
  • Arduino Sketchers
    Vije Miller04/16/2016 at 19:10 0 comments
    // Bowel Gauge _ @TVMiller
     #include <LiquidCrystal.h>
     LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
    int ssr;
    int sensorstart = 0;
    void calibrate() {
     lcd.setCursor(0, 0);
     lcd.print("Calibrating...");
    for (int x=0, x<10; x++) {
     ssr = analogRead(A0);
     sensorstart = sensorstart + ssr;
      delay(100);
     sensorstart = sensorstart / 10;          // Average
     lcd.clear();
    void setup()
     lcd.begin(16, 2);
     lcd.clear();
     calibrate();
    void loop()
      int sensorlive = analogRead(A0);       // Live reading
       int dif = (sensorlive - sensorstart); // Subtract calibrated reading
        float difsol = dif * 0.191;          // Variance to fl oz per 40 oz
         float difoz = difsol * 1.0425;      // Convert fluid to solid ounces
         if (difoz < 0) {
     lcd.print("0.00");                      // Remove negative fluctuations
     } else {
     lcd.print(difoz);                      // Print OZ
     lcd.setCursor(6, 0); lcd.print("OZ");
     lcd.setCursor(11, 0); lcd.print("BOWEL");
     lcd.setCursor(0, 1);
     lcd.print(millis()/1000);               // Print SEC
     lcd.setCursor(6, 1); lcd.print("SEC");
     lcd.setCursor(11, 1); lcd.print("GAUGE");
      delay(100);
  • 69/074
    Vije Miller03/10/2014 at 23:24 0 comments
    LCD was fried (don't ask) which was ordered and arrived. Currently testing a low pass filter versus coded smoothing to level the inevitable erratic sensor.
View all 2 project logs
  • 1
    Step 1
View all instructions
Jarrett wrote 04/16/2016 at 20:53 point
Gonna install one in my hackspace and hook it up to a leaderboard
Vije Miller wrote 04/16/2016 at 21:12 point
Some one takes a new lead, begin.println("BOOM"); and colorful LED celebration, Twitter update...love it.
