Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Control Stack
This stack is the catch-all for incoming and outgoing data.
jlbrian7jlbrian7
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
28 followers
  • Description
  • Details
  • Files 0
  • Components 13
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
467
0
28
4
Team (1)
  • jlbrian7jlbrian7
Join this project's team
  • Motor Driver
  • Yaw-Pitch-Roll
  • Depth Transducer
  • Comms
  • Interface
  • Motor Controller - Stellaris
  • dirty boards
  • BBB Code
  • Sensor Board - Stellaris
hardware
ongoing project
arduino ROV telemetry MATE ROV 9 dof yaw-pitch-roll Stellaris launchpad
This project was created on 01/22/2015 and last updated 7 years ago.
Description
Breaks apart communication string and sends motor data to motor controllers, operates 'altimeter' and 'tape measure' , handle communication from depth sensor (if I get it working) and 9 dof sensor stick. Also provides break out for additional features.
Components
  • 2 × TI Stellaris Launchpad
  • 1 × 3v3 Arduino Pro Mini
  • 4 × TIP102 Discrete Semiconductors / Power Transistors and MOSFETs
  • 4 × 10x2 Stackable Headers
  • 4 × 10x2 Female Headers
View all 13 components
Project Logs
Collapse
  • Bench Test
    jlbrian7 • 02/14/2015 at 18:23 • 0 comments
  • Build and wait, build and wait.
    jlbrian7 • 01/29/2015 at 21:57 • 0 comments
    Getting closer to a full system test.
  • No Smoke.
    jlbrian7 • 01/29/2015 at 02:40 • 0 comments
    The blue led's on the board are for the 9dof sensor stick and the UI gets a NaN if there is no data, so looks like this is working.
    And the red led shows it is receiving joystick commands.
    So happy to be rid of the rats nest I had on my desk!
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Brought to you by Digikey and Hackaday Prize: Develop a Universal Sensor Hub, with MachineChat's JEDI One and a Pocket Beagle.
Project Owner Contributor
Machinechat: A Universal Sensor Hub
LutetiumLutetium
Home Automation and Monitoring System with many sensors and actuators to keep your home safe
ED-E: Home Automation and Monitoring System
Tyler SpadgenskeTyler Spadgenske
4'33" redux
Ultrasonic Sensor Data for Fun & Profit
Aleksandar BradicAleksandar Bradic
A LoRaWAN based environment sensor connected to the Helium network and miners. The live data comes on a google sheet with helium integration
LoRaWAN Environmental Sensor Google Sheet Helium
akarshagarwal98akarshagarwal98
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "Control Stack", please tell us the reason.
Send message
Remove Member
