I like the table view of the solar voltage and current but it was more of a pain to parse the output for automatic data collection so I update the output to just provide a single string output with the label, voltage, current and watts. I used a simple bash script and curl to pull the web data every 5 minutes and create a CSV file.
Web page view from arduino.
Bash Script......
#!/bin/bash
date=`date`
CMD=`curl -s 192.168.1.177 | grep Panel`
source=`echo $CMD | awk '{print $1}'`
volts=`echo $CMD | awk '{print $2}'`
amps=`echo $CMD | awk '{print $3}'`
watts=`echo $CMD | awk '{print $4}'`
echo "$date,$source,$volts,$amps,$watts"
crontab entry to pull the data and save it in a file
*/5 * * * * /home/gary/getpower.sh >> /home/gary/solarout.csv
Gary
